Welcome to the Downeast Boat Forum, the premier website dedicated to the Downeast Boat enthusiast! Sign up today and talk with other Downeast Boat enthusiasts about everything from Lobster Boats, Downeast Cruisers, Lobster Skiffs,Long-lining Boats, Sword Fishing Boats, Downeast Boat Projects/ Repairs,Downeast Boats for Sale,and Downeast Boat Design. And of course what would a Downeast boat forum be without chatting it up with other members about Tuna Fishing, Lobstering, Striped Bass, Live Bait (Pogies,Herring,Mackerel), Fishing Reports, Lobsterboat Races, Fishing Gear, Downeast Boat Pictures, Charter Boats, ETC
Home Register Pictures FAQ Members List Search Today's Posts Mark Forums Read
Go Back   Downeast Boat Forum > Downeast Boat Forum > Downeast Engine Room
Reply
Thread Tools Search this Thread Display Modes
Old 11-28-2012   #1
CEShawn's Avatar
Likes (Given): 918
Likes (Received): 718
Default Emergency Bilge Suction
Every boat I have ever had has had an emergency bilge suction off the engine.
This is my first boat that has a engine driven washdown pump common on downeast boats.
1. I should put a "wye" valve in here to be able to take a suction from the bilge right, as that should be my first emergency pump to use as to not damage the engine correct?
2. Should I still hook up a way for the main engine to suck water out. Granted I know that you risk losing the main engine with crap in the impeller. Of course a strainer of sorts is good to have.
So what do you guys have for suctions?
1. My first setup was a hard piped suction to the bilge with a Perko pump strainer, drop in end of the pipe one. This was done with two globe valve and the installer's idea was to be able to throttle what you wanted to pull out of the bilge, I did test it but always fearing of taking water back in this way too.
2. The second and third boats always had it on a Groco Safety Ball valve.
Not sure which route to go with here and since this board has been to helpful I figure I would ask.... Thanks...
CEShawn is online now   Reply With Quote
Old 11-28-2012   #2
F/V First Team's Avatar
Likes (Given): 0
Likes (Received): 1953
Default
SBV for the win!
__________________
Otis Enterprises Marine
SisuDiesel North American Sales & Service
(207) 548-6362
travisyourinboxisfullagain@otisenterprisesmarine.c om
Chances are my inbox will be full, email me
F/V First Team is online now   Reply With Quote
Old 11-28-2012   #3
CEShawn's Avatar
Likes (Given): 918
Default
Roger that, its the one I am used to and forgot how much I liked the flushing feature!
Old 11-28-2012   #4
Likes (Given): 0
Default
I think I would actually argue with an owner to put one in, it's just a no-brainer.
__________________
(207) 548-6362
Old 11-28-2012   #5
CEShawn's Avatar
Likes (Given): 918
Default
What do you think, also throw one on the deck washdown pump as well?
Sponsor Advertising • Downeast Boat Forum is enhanced with content-revelevant advertisings.
Old 11-28-2012   #6
Likes (Given): 0
Default
Anything that can move massive amounts of water and/or needs to be winterized should have a system that can be used quickly and easily
__________________
(207) 548-6362
Old 11-28-2012   #7
CEShawn's Avatar
Likes (Given): 918
Default
Maybe I can even add this for right now on GENNY and this SW pump. Agree with the winterized bit...
Groco SSC Engine Flush Kit (Safety Seacock Conversion)
Old 11-28-2012   #8
Badlatitude
1000 Post Senior Member
Badlatitude's Avatar
Likes (Given): 1111
Likes (Received): 467
Default
We had a T off the engines water pump along with one off the engine driven wash down pumps. I would never own an inboard that didnt. Its definatly a no brainer.
Had to use mine too.
Badlatitude is offline   Reply With Quote
Old 12-01-2012   #9
Tuckerman
500 Post Senior Member
Tuckerman's Avatar
Likes (Given): 92
Likes (Received): 403
Default bilge pump
I have a 22 webco outboard boat. I put a 3700 rule washdown pump and plumbed a crash valve onto the pick up. I figured I have that pump might as well have it available if the sh$@ hits the fan. If I shut off thru hull and open valve on left pump will pull from bilge and i can put my 1 1/2" washdown hose overboard. I have a light weight zip tie holding valve closed so it cant be opened by mistake.
Tuckerman is offline   Reply With Quote
Post Thanks / Like - 1 Likes
Likes CEShawn liked this post
Old 12-03-2012   #10
backman
Likes (Given): 36
Likes (Received): 215
Default
who makes that throughhull and what's the rough cost?
backman is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vBulletin Skins: WebSkinsPlus.com
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
