2001 Volvo D12
Discussion in 'Downeast Engine Room' started by SPINE-A-LINER, Jul 25, 2017.
  1. SPINE-A-LINER
    SPINE-A-LINER Member
    Aug 18, 2016
    17
    6
    Rye, NH
    Blue Fin Islander 27'
    I'm currently looking to purchase a boat with this engine. I know Volvo engines are typically more expensive for routine maintenance. This engine only has about 350 hours on it. I'm curious about any pros and cons about this motor. At WOT it spins at 2200 rpm and 25 knots. At cruise of 20 knots it's at 1800 rpm and about 1.1 mpg.
    Thank you for any input!
  2. Downrigga
    Downrigga Captain
    Mar 25, 2016
    648
    267
    Harwichport MA
    36' NB
    The D 12 is a very good reliable marine engine. Speaking from experience because I own one. Trouble free. I don't find it any more expensive for routine maintenance. You don't need to purchase Volvo filters.
    Dr Dude likes this.
  3. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    Thanks Downrigga. Is your engine in a 36' NB? What do you get for cruise and WOT and rpm with that engine/hull? Thank you. That's a beautiful boat you have there!
  4. Downrigga
    Downrigga Captain
    Mar 25, 2016
    648
    267
    Harwichport MA
    36' NB
    Yes a NB. I cruise between 26 and 28. Its a 2300 rpm motor.
  5. jim
    jim Captain
    Jan 4, 2012
    818
    835
    Retired FDNY, commercial tuna/sword handgear
    Rockaway, NY
    48ft Dixon
    I had a D12 550hp in a 42 H&H she maxed out at 1900 had 14+k hours on her and never missed a beat. There are a few commercial guys in Barnegat with well over 35k hours on them with no major work done. Great engine. The guy I bought the H&H from had a new Mussel Ridge built and he put a D12 in her. Hes a full time commercial high liner. That says a lot about the D12. Good luck!.
    jim,
  6. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    Thank you Jim and Downrigga. What size prop do you spin on your NB Downrigga? I think this boat I'm looking at may be over propped?
  7. Frank Grimes
    Frank Grimes Captain
    Dec 20, 2011
    1,074
    290
    N41°41'46.91" W070°15'35.13"
    are you looking at the blue NB 36 that's on YW? The performance #s on that boat don't seem right to me, unless she's got a ton (literally) of lead in the keel she should top out close to 30 on the pins. Cruise should be 23-24
  8. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    Yes. I've got a deposit on her. I took it for a spin and it definitely doesn't get max rpm at WOT. I know boats get heavier with age(like me) but I think the prop may need some work to get her to 2350+\- rpm. I think she is built pretty heavy with all the wood in the interior. I don't know what size prop it is yet but I want to find out and compare #'s. Thanks
    tailhook likes this.
  9. Downrigga
    Downrigga Captain
    Mar 25, 2016
    648
    267
    Harwichport MA
    36' NB
    I can not tell you exactly what size prop. Its either a. 26 sq or a 28 sq...whichever one is the biggest you can put on the 36. How many hp are you?
  10. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    its a 700 hp D12
  11. Downrigga
    Downrigga Captain
    Mar 25, 2016
    648
    267
    Harwichport MA
    36' NB
    Put an injector cleaner in the fuel . How many did she make? Has the boat been sitting?
  12. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    I will try that for sure. Great idea. It has been sitting as it does not have many hours on the motor.
  13. Downrigga
    Downrigga Captain
    Mar 25, 2016
    648
    267
    Harwichport MA
    36' NB
    The growth on the bottom and maybe even the prop will effect your rpms. Don't be afraid of the motor.
  14. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    Thank you.
  15. tunaorlater
    tunaorlater Captain
    3,723
    1,879
    LIPA lineman
    She has Dqx 28" wheel. I don't remember the pitch though. 28x26 will probably do the trick. That boat loves a 3 blade wheel if you want to get more speed out of her but she won't be as smooth as now I'm sure.
  16. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    Thank you tunaorlater
  17. cb34
    cb34 Captain
    Oct 31, 2011
    857
    176
    Whats with the name Spine.........DC?
    cb34,
  18. SPINE-A-LINER
    Aug 18, 2016
    17
    6
    Rye, NH
    Exactly
