2019 28' BHM - Coming Along in Boothbay
Discussion in 'Classifieds for Downeast Boats' started by neyachts, Sep 14, 2018.
  1. neyachts
    neyachts Senior Member
    Feb 8, 2012
    271
    Yacht Broker - 100T USCG 9th Issue
    York, ME
    28 Seaworthy (BHM) Hull #30; 45 YB; 35 Jason; 29 Blackfin; 17 Montauk
    Sep 15th - The new build 28' BHM is progressing nicely, and Bob Peters is incorporating his artistry and skills into this boat with every step.
    It's being built as a spec boat, and is currently for sale. Please check out the YW listing:
    2018 Downeast Fisherman/Cruiser Power Boat For Sale - www.yachtworld.com
    Windows just went in this week...
    If you want to swing by and have a look, please call or text me first, so I can let him know. Larry 603 433-3222. Thank you!
  2. neyachts
    Feb 8, 2012
    271
    York, ME
    Oct 12th - Nearing completion! Come have a look...
    • SPECIFICATIONS:
    • 2018 28’ BHM
    • LOA – 28’
    • Beam – 10’6”
    • Draft – 3’8”
    • Displ – 10,600#
    • Engine installed with heavy-duty aluminum beds, back-up plates and SS bolts through stringers.
    • Engine stringers all reinforced with knees glassed to stringers and hull.
    • Shaft tube with two cutlass bearings: one forward, one aft with PSS shaft seal.
    • Shaft is SS 1-3/4".
    • Exhaust system installed - includes 4" Centek muffler, 4" checkvalve and exhaust thru-hull with flapper on transom.
    • Steering system installed including a helm 1250V Capilano 3-6 LTOR; cylinder is a Capilano BA 150-7 TMB, with ball joint, bronze tiller arm, heavy duty hydraulic lines run in PVC piping from ram to helm.
    • SS Helm Wheel with quick steering knob.
    • Rudder installed - 3/8" 304 SS with 1-1/2" shaft. All bronze mounting hardware. Interior reinforced extra thick glass for additional strength.
    • Complete Bonding System - Large Transom Zinc on bronze plate; #4 gauge tinned copper marine wire run to all required locations. No 'daisy-chain' system. All wiring in PVC pipe where possible. All lugs are heavy duty tinned copper covered with epoxy heat-shrink to stop corrosion.
    • Bilge pump is Rule 1100gph with built-in float switch. Includes SS hose clamps, marine hose, and bronze thru-hull fitting. * GROCO Bronze Sea Cock 1-1/2" for engine intake, in bronze thru-hull fitting.
    • GROCO Bronze Sea Strainer.
    • Buck Algonquin Bronze scoop strainer, positive flow design. This is a double protection system from grass and other debris entering engine intake/strainer.
    • Air flow/distribution system through multiple air boxes.
    • Custom Engine Box.
    • Bow and Quarter Spray rails.
    • Bottom Paint - Barrier Coated, Finish Coat
    • 2018 Yanmar 8-LV Series 370hp Diesel, Full warranty (960#)
    • Engine pk Includes: LCD Display, ignition switch, drive harness, backup panel, drive ECU, gear cooler with lines, 180-amp alternator, H.D. Berry engine mounts, helm ECU, exhaust elbow, helm harness, dual dipsticks, single top-mount control head and all operating manuals.
    • Gear = Yanmar KMH50A
    • ESTIMATED CRUISE = 22kts @ 7gph - Top: 27kts
    • Gauge Package, Electronic Single-lever Engine Control
    • Fuel tanks, - 2-5052 Aluminum, 60gal ea – total 120gallons, epoxy coated with 2” SS Fills
    • Two Fuel Gauges
    • Racor Fuel/Water Separator Filter
    • Running Gear, 1-3’4” Acumet Shaft; SS Rudder
    • Michigan Nibral Propeller, 4-Blade, 21” x 21” with a #5 Cup
    • PSS Shaft Seal
    • Marine Batteries (2- House and Start)
    • Two Electric Panels
    • 30-Amp Battery Charger with Panel Mounted 110vac outlet receptacle
    • IN ADDITION:
      • Four Opening Ports in Cuddy, Smoked Glass with Screens
      • Cuddy Bomar Hatch in Overhead
      • Black Aluminum Wynne windows, with Helm Opener
      • Open House Back
      • Black Composite Rub Rails with stainless trim
      • GARMIN Electronic Package includes Radar, GPS Charplotter, Sounder, VHF Radio with associated Transducers and Antennas
      • Port-a-Potti on Platform in Cuddy
      • Saltwater Washdown
      • Fresh Water Washdown – 9 Gal tank – Gunwale Fill
      • Enclosed under-gunwale storage lockers each side
      • Two 19”x22” Anchor aluminum deck hatches
      • Stainless Bow Bit, Chocks, Cleats
      • Nonskid on Pilothouse Roof
      • Fixed Pedestal Helm Seat
      • V-Berth Below with storage under
      • Port Cuddy Cabinets Below
      • 2 Rod Holders
      • Builder’s Risk Insurance (extra cost)
      • Sea Trial Travel, Fuel and Launch (extra cost)
    Call or text Larry @ 603 433-3222.
  3. F/V First Team
    F/V First Team Captain
    6,032
    2,313
    It's not a Spencer Lincoln design...
    If anything, it's Jim Beam's design
  4. neyachts
    Feb 8, 2012
    271
    York, ME
    Yes, there was some talk in the 'early days' about that composite design, and as you informed me in our last conversation, it was a 'cut-down' 31'. Am I correct? Jim Beam produced the first 28', but didn't Spencer take credit for it original drafting?
  5. F/V First Team
    6,032
    2,313
    David McGraw worked with Royal Lowell to create the 31 I do believe
    After that, the 28 came about with a pair of scissors to prove Spencer wrong who was also sitting at the table
  6. neyachts
    Feb 8, 2012
    271
    York, ME
    Ah yes, the intrigue continues. It's a shame the 'real' designer has never gotten credit, don't you think?
  7. F/V First Team
    6,032
    2,313
    Being...? I always felt that David and Royal got credit
  8. Henfruit
    Henfruit Senior Member
    Aug 22, 2016
    387
    149
    SC winter Deer Isle Summer
    Samson 30
    Where’s the horn
  9. Frank Grimes
    Frank Grimes Captain
    Dec 20, 2011
    1,245
    351
    N41°41'46.91" W070°15'35.13"
    I've seen it the BHM 31' attributed to Spencer in multiple places. That would be news to a few.
  10. BHC.com
    BHC.com Member
    Aug 8, 2017
    72
    19
    Pretty sure he’s refering to Jim Beam, the booze
