22 Northern bay
Discussion in '"Pocket" Downeast Boats (14-24ft)' started by jdickau484, Sep 18, 2017.
  1. jdickau484
    jdickau484 Senior Member
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
  2. kcassells
    kcassells Senior Member
    Jan 10, 2015
    104
    14
    Phila Master Plumber
    Pa
    Nice work there son the tabbing. Looks real clean.
  3. jdickau484
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
    Thank you
  4. jdickau484
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
    Filled a couple sections with foam. Man this stuff sucks grinding. Little smoothing I.T out left to do. Hole saw cut out of the stringers.
    david likes this.
  5. SeaKarma
    SeaKarma Senior Member
    Apr 26, 2014
    217
    252
    Merrimack River, MA
    Looks good! Just curious, what was the reasoning behind the foam filling? Was it a structural decision?
    david likes this.
  6. kcassells
    Jan 10, 2015
    104
    14
    Pa
    Nice clean work. That foam will add some support to floor, deaden sound and flotation always helps. 2# foam? ;)
  7. jdickau484
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
    thanks guys. Yes it is a 2 lb foam from Mertons. I am hoping the foam will make the hull sound better in a chop, that's the maIn reason I went with it. This was a suggestion from GM.
  8. Keelboater
    Keelboater Captain
    3,593
    1,559
    Nice work! Is the Airex transom core overlapping the original core to build it up for the bracket? In post #32 it looks like Divinycell has already been bonded to the transom. You might want to consider giving the top surface of that new foam a coat of resin before the floor goes down just to seal it up. You're doing a great job and that pilot house is going to look perfect when it's installed.
    Ah, I just re-read post #1 regarding the transom. I get it now.
    kcassells likes this.
  9. jdickau484
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
    Thanks Keel! I thought an inch divinicell core on the transom seemed a little light. Saw a lot of boats with inch and a half coosa cores for the transom so wanted to beef it up. Was debating if I should cap off the foam sections, was going to ask. Think I will do that.
    Will the Bruno go in this spring?
    Keelboater likes this.
  10. catchthis
    catchthis New Member
    Sep 20, 2013
    can you give me any info on the bracket? I just picked up a project 20' dynamic composites which I believe to be the Mitchell cove/ CB hull. It was an I/ o but I'm planning either a bracket or transom notch. I'll start a new thread with some pics so I don't hijack your thread. If you have any info on the bracket builder and price I would appreciate the help! Your boat looks beautiful stretched 2'!
  11. kcassells
    Jan 10, 2015
    104
    14
    Pa
    Yup you can cap off the foam sections. I think epoxy {glass optional} is what you want to use. If I recall poly will melt the foam.
  12. jdickau484
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
    Ya man I’ll send you some info. Got a couple quotes from some other bracket guys too. I also have a template of transom angle, curve etc. will get you this info mid week.
    Cassels, I believe the 2 lb isn’t affected by poly. Thought I.T was other foams that were affected by uncured poly. I gotta look that up. I don’t have any experience with I.T though.
  13. kcassells
    Jan 10, 2015
    104
    14
    Pa
    Here ya go...wasn't sure. Us Composites who sekks it says;
    • Once fully cured this foam can be laminated over with any type of polyester, epoxy or vinyl ester resin without melting.
    jdickau484 likes this.
  14. Keelboater
    Keelboater Captain
    3,593
    1,559
    Yes, the Bruno is going in one way or the other! :D Probably looking at June some time. I hope to see you out at Block!
    jdickau484 and Genius like this.
  15. jdickau484
    Nov 25, 2012
    302
    252
    Ninigret Pond, RI
    Thanks for that Cassels!
    Will see you over there Keel!
  16. catchthis
    Sep 20, 2013
    Hey, just wanted to thank you for getting back to me with some info on the bracket options. I will post some pictures by next week, going up north for a few days and sadly dont have pics on my new phone!
