25 General Marine budget build
Discussion in 'Downeast Projects and Boat Building' started by Frontier, Jun 14, 2017.
  1. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    How it sat when I went to look at it FB_IMG_1492655900068.jpg FB_IMG_1492655914990.jpg FB_IMG_1492655925912.jpg
    Toolate likes this.
  2. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
  3. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Beginning of teardown 20170609_113348.jpg 20170609_113326.jpg 20170609_113323.jpg 20170609_113338.jpg
    restless likes this.
  4. restless
    restless Captain
    Jan 22, 2014
    1,620
    996
    Good luck with your project. Looking forward to following your progress.
    blackfish84 likes this.
  5. speedwagon
    speedwagon Senior Member
    Dec 10, 2014
    191
    47
    PJ RI
    Subscribed. Is that a clean out plate in in front of the rudder?
  6. SeaKarma
    SeaKarma Senior Member
    Apr 26, 2014
    269
    359
    Merrimack River, MA
    Nice! Best of luck with the project, and congrats.
  7. Keelboater
    Keelboater Captain
    4,020
    1,919
    Clinton Harbor & North Cove
    Good luck with your project! It's nice to see that Joe Boat is still moving things around.
  8. Brainey
    Brainey Senior Member
    Aug 29, 2013
    414
    116
    Manager - Environment, Safety and Health Departmen
    VA Beach VA
    Momentarily Boatless
    Go for it - good luck!
  9. El Mar
    El Mar Captain
    6,304
    2,145
    Last I heard he sold most of the equipment and is going into the canvas business.
  10. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Yes, that is a clean out.
  11. BillD
    BillD Captain
    5,559
    1,308
    Business owner
    I really like following these "project" boats. Brings back memories...
    What is your "to do list" for the whole boat ????
  12. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Stern cap, was completely covered in 10+ layers of house paint 14975474166471707355308.jpg
  13. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    The boat went under at some point and assume its been sitting since.I'm going in stages, starting with cap and gunnels. I've removed the rails, sanding it down to gel coat, fill in all the hatches and holes. I have already cut out the built in lobster boxes on each side. The cap in bow starboard side popped up, so I need to pull that back into place. The stern had some funky cutout, then a bad repair job, I'll post some pics shortly, and get some thoughts how to correct it.
    The floor will be cut out, at which point I'll remove the 350 MPI FWC, and get into condition of the thru hulls, shaft and tube and go from there.
    What's nice about this GM is how modular the pieces are, and aside from the deck everything seems to be cored with Divinylcell.
  14. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    I got an hr in before the rain. A crimped wire wheel on grinder then 120 grit with the DA worked well
  15. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Here is the cut out that needs to be re-repaired
    JimRP31 likes this.
  16. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Got some work done on the gunnels, more derigging and removed rub rails from the back half. Doesn't look like much, but a lot of effort into it
    Keelboater and Toolate like this.
  17. BillD
    BillD Captain
    5,559
    1,308
    Business owner
  18. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Thanks Bill, I read through your rebuild thread several times, a top notch project for sure.
    After both sides are ground down, I'll be pulling the floors. Looking forward to see what's happening down there
    EricH likes this.
  19. kcassells
    kcassells Senior Member
    Jan 10, 2015
    197
    39
    Phila Master Plumber
    Pa
    Progress report required....please.
    SeaKarma likes this.
  20. Frontier
    Frontier Member
    Nov 23, 2016
    87
    70
    Sorry for the lack of reports. Ive sanded most of the gunnels, and working on filling the rails and repairing the stern cap. I removed the rub rails and reseated the cap in the bow. Cleared out the cabin.
    Next up will be cutting the floor and pulling the old 5.7
    20170918_111822.jpg 20170918_111842.jpg 20170918_111834.jpg 20170918_111857.jpg 20170918_131931.jpg
