25 General Marine budget build
Discussion in 'Downeast Projects and Boat Building' started by Frontier, Jun 14, 2017.
  1. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    The boat got wrapped and ive been working inside. The bulkheads are filleted in , sistered a pc to the center bulk for strength and to help hold where the single exhaust will Y into and ive got a few layers of 1708 on the fuse box cutout on the house bulkhead. I tried to put one a large single sheet of glass where the motor cutout is, it didnt hold and all hell broke loose trying to deal with it, live and learn. 20171125_143008.jpg 20171129_102720.jpg 20171129_102758.jpg
  2. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    I pulled the clean-out port, prepped and polished it on the drill press.
    Also picked up a wheel on the cheap, turns out its 1" tapered instead of straight shaft but i really like it so i think ill have it bored and the keyway machined in if its not to much money
    And got this hauler and a hot coffee from a nice lady nearby, for a few bucks. i bench tested it and it works fine. Not sure the maker, and never seen one like this but it looks like an Electradyne with regard to the parts. Theres a little wobble between the gear and backplate that needs to be shored up, otherwise good shape. I polished the face plate too.
    How do these electric hauler get mounted on the bulk wall? Does the gear and drive get pulled off. Looks like the drive shaft gets pressed on
    CEShawn likes this.
  3. CEShawn
    CEShawn Captain
    Sep 21, 2011
    2,871
    857
    RP35
    Great thread, love the prop clean out... makes me miss my GM26, sometimes feel the RP35 is to large... Please keep posting, I am oversea's now and not getting to play on boats, working on ships... much different...
  4. kcassells
    kcassells Senior Member
    Jan 10, 2015
    241
    44
    Phila Master Plumber
    Pa
    Dang...that's one tightly enclosed boat wrap! Probably a lit pack of matches will heat it up now.
    Looking good! Back out to my leetle project now.
  5. Keelboater
    Keelboater Captain
    4,136
    2,027
    Clinton Harbor & North Cove
    Making some good progress and the ability to work "indoors" will sure help. I hope no fast moving plow trucks make a habit of throwing snow over the side of that bridge. :eek: Hopefully your boat is out of range for a slush party.
  6. General Marine Inc.
    General Marine Inc. Senior Member
    Nov 14, 2015
    271
    380
    Boat Builder & Sales
    Biddeford, ME
    Fiberglass dust is highly flammable and using an open flame heater like a torpedo heater in a small tented space like that can be really dangerous. A Pelonis radiant heater a better option and will do a great job heating the space and most of them run about $60 or so at HD.
    ErikT likes this.
  7. CEShawn
    CEShawn Captain
    Sep 21, 2011
    2,871
    857
    RP35
    GM where can I get my next GM25 to play with :)
    General Marine Inc. and SeaKarma like this.
  8. kcassells
    Jan 10, 2015
    241
    44
    Pa
    Thanks for the insight! Not much dust in confined winter work.
    Thank you.
    SeaKarma likes this.
  9. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    I missed the itch, so went ahead and removed the previous transom repair.
    Just some updates, not to much to see. Fuel line chase, engine cutout fairing
  10. Toolate
    Toolate Captain
    5,183
    1,373
    Building contractor
    Bilge came up clean! Man this takes me back...
    Keep at it, spring is coming!
    Frontier likes this.
  11. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    Split the cutout and chipping away on the balsa core
  12. steveinak
    steveinak Captain
    4,287
    1,671
    H&H / Pen Bay
    I'm 99% sure the motor & gearbox are from Electa Dyne, look for the allen head set screws on the couplings. If you need parts just call Judy or Larry at ED they will fix you right up.
    Frontier and sailor of fortune like this.
  13. kcassells
    Jan 10, 2015
    241
    44
    Pa
    At least you got something going. Thanks for the fix/update. Can't get my arse out into the boat with 7 degree weather.
  14. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    Worked on prepping the transom skin for reglassing 20180120_153820.jpg 20180120_141612.jpg
    And tried few ways to get the cutless out but no luck. And stripped a set screw in the process.
    So i pulled the housing, which was probably a good idea anyway, and ill do it on the bench
    Keelboater and restless like this.
  15. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    Not fun, but done.
    Next time ill use a press
  16. Freshwater
    Freshwater Senior Member
    Aug 24, 2015
    107
    48
    Electrical utilities
    Michigan
    But if you had a press you wouldn’t have had to engineer your contraption
    To y
  17. Toolate
    Toolate Captain
    5,183
    1,373
    Building contractor
    And free is free- that’s how shit gets done!
  18. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    Transom is back!
    Close to laying out all the under deck items, then gelcoating up the bilge.
    Shaft and prop are ready for pickup from Hale Propeller
    Ill be installing the cutlass back into the tube tomorrow
    On the hunt for some decent $ seacocks and adding mounting pads for those
    Things feel like they are moving quicker with the project finally
    Bill likes this.
  19. Frontier
    Frontier Member
    Nov 23, 2016
    90
    78
    And the stern cap is mostly done, just some finish fairing left
    ErikT and Keelboater like this.
  20. General Marine Inc.
    Nov 14, 2015
    271
    380
    Biddeford, ME
    Frontier, I was mistaken about max tank size that will fit under the stern cap. Max is 106 gal not 90. Tank measurements as follows:
    106 Gallon - 72"W x 19"H x 17.5"D
    92 Gallon - 70"W x 18"H x 15 &7/8"D
    - Dave
