25 General Marine budget build
Discussion in 'Downeast Projects and Boat Building' started by Frontier, Jun 14, 2017.
  1. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
  2. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    Frontier how are you going to use that bell housing and coupling to make up to your gear. ? I 'm pretty sure that coupling and bell housing came off a outdrive.
    Keeper47 likes this.
  3. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    Good eye, i do have the fly wheel, coupling and housing with high mount starter location that fits the gear. I think all ill need before install is a high amp alt
  4. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    Yeah don't forget the starter has to run in reverse from the standard bottom mounted one. Did you ever find a fuel tank ?
  5. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    No, its the last major item I need. I found a new tank that needed a few inches off the length and fill moved, but it was $1G total.
    Worse case ill run a temp tank and hope to get lucky down the road
  6. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    I know a guy that just revamped his 25 and he may have the aluminum one. He replaced it with a 45 Gal one. Unless he has sold it he also has a rebuilt Velvet drive 1.9.1 with about 4 hrs on rebuilt.
  7. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    Id be interested in the tank for sure, i have a 2.5 borg warner going in, its a 21x21 wheel
  8. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    Ok I'll check tomorrow to see if he still has it.
    Frontier likes this.
  9. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    Chris, here it is. Sorry i couldn't post them in the PM.
  10. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    I think that will work, definitely length/ width, ill double check the height will fit tmrw morning.
    THANK YOU!
    This forum is the best
  11. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    No problemo.
  12. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    An idea of how the exhaust will be mounted
  13. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    And 2-1.5" seacocks will go here. Theres a mounting pad for one and i added a 1/2" FRP base for the other that just needs the thru hole bored. This is where they were originally.
    You can see the small hole next to the inboard stringer where the transducer previously was, anyone have thoughts on placement for an Airmar flysh mount ducer in this bulk
  14. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    Chris, that exhaust system looks ok but it should be straight as you can make it so it wont hold water when you haul it in the winter. It would be good if you could extend that port side tube forward to make a surge tube. You would need another y forward of that one you have. I'm not sure you have room under that manifold for that though. Also it would be good to put that system together with T bolt clamps, 2 on every joint. Remember you may not be able to get to that whole system as some will be under the deck with no hatch above. Everything under the waterline should be two clamps.
    You should also make sure you get all the hookups on that engine that you can before you install it. It will be pretty tight in there. Even if you have to pull your manifolds you will have to haul the engine up. Also i don't think those elbows will work because the are oval on the bottom side.
  15. Old Mud
    Old Mud Captain
    3,608
    2,774
    Retired Fisherman
    Any updates ??
  16. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    Thanks again for the help on the tank!
    Today i drilled the thru hull hole in the pic above and glassed down the first 1/2" FRP block for the engine intake thru hull.
    Also sanded down the transom where an exhuast hole was, should ve ready for fill, fair and gelcoat as soon as the weather warms a little.
    Old Mud likes this.
  17. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    Sanding off 30 yrs of bottom paint in prep for barrier coat
    Motor and trans are together and ready for install
    Rolling some gel coat
    20180607_135351.jpg 20180607_135401.jpg 20180607_135423.jpg 20180607_140036.jpg 20180607_140046.jpg 20180607_140056.jpg
    93vecter, kcassells, CEShawn and 2 others like this.
  18. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    20180707_152343.jpg 20180708_130952.jpg 20180707_152348.jpg 20180708_130637.jpg 20180708_130630.jpg
  19. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    Couldnt find a cheap used pulpit for the drum winch i picked up, 20180708_150331.jpg 20180708_130316.jpg 20180708_130255.jpg 20180708_130325.jpg 20180707_163549.jpg 20180707_163129.jpg 20180707_163129.jpg so started building one
  20. Frontier
    Frontier Member
    Nov 23, 2016
    97
    96
    Building a 20180708_131834.jpg brace to hold the roof and remove the post. 1/4" FRP, it will go all the way to the console
    Blitzen and Old Mud like this.
