27' H&H Wheel Size
Discussion in 'Downeast Engine Room' started by PatrickPresti, Jul 12, 2018.
  1. PatrickPresti
    PatrickPresti Senior Member
    May 2, 2013
    342
    26
    Ferry Captain/Mechanic
    Islip, NY
    Hi Guys,
    I have a 27' H&H with a 350 Mercruiser Horizon and a ZF 2.5:1 turning a 21"x17" 4 blade propeller. I had it at WOT today and it was turning 5500+ RPM's.
    Does anyone know if this is the correct propeller size?
    I need to hand tach the the engine and gear to start eliminating stuff.
    Any help would be greatly appreciated!
    Pat
  2. BillD
    BillD Captain
    5,555
    1,306
    Business owner
    Kittery Maine boat ?
    If so, very very nice 27 H&H
  3. Captinlon
    Captinlon Member
    Mar 28, 2016
    52
    6
    Coast of Maine
    32 H & H
    check your engine spec but I think your right on the money. if I remember right my merc horizon only turned 5500 rpm
  4. PatrickPresti
    May 2, 2013
    342
    26
    Islip, NY
    I thought it was between 4800-5000 RPM's....
  5. PatrickPresti
    May 2, 2013
    342
    26
    Islip, NY
    Thanks. Yes it is but it seems awfully slow to me. I thought it would have been faster with the 5.7 MPI. I'm concerned with it turning up to 5500-5600 RPM's...
  6. xbskt
    xbskt Captain
    1,240
    925
    electrician
    28 Crowley Beal
    Depending on specs. If you are over spinning but happy with performance then you are under propped and your engine says Thank you. Unless you plan on 5500 all the time. Then not so much...
    What speed was WOT?
  7. PatrickPresti
    May 2, 2013
    342
    26
    Islip, NY
    I just ran it real quick yesterday. I didn't look at the speed when I was turning 5500-5600 RPM. I am going to photo tach it over the weekend to eliminate any tach or transmission issues. I will post once I get more information...
  8. PatrickPresti
    May 2, 2013
    342
    26
    Islip, NY
    I was hoping to get a 17 knot cruise but I don't know if that's possible?
  9. BillD
    BillD Captain
    5,555
    1,306
    Business owner
    I sea trialed the boat before you purchased it. I recall the owner saying he cruised @ 4400 rpm.
    I think 18 knots was the number...boat moved right along for a 300 hp Merc. The "350" designation could be the torque...not sure.
    I was assessing the 27 H&H for maybe an engine upgrade to a 480 QSB 5.9 2:1 gear...22 knot easy cruise.
    Very very nice boat !
  10. PatrickPresti
    May 2, 2013
    342
    26
    Islip, NY
    The "350" is the Cubic Inches of the engine. It's a 300 horsepower engine. I don't need to cruise at 22 knots. I'm okay with 17 knots. I will get better numbers over the weekend...
  11. eyecatcher
    eyecatcher Member
    Sep 30, 2012
    93
    22
    it should be 4600 -5000 RPM probably could go with two inch more of pitch if everything else checks out
