35 Duffy 400HP C-Series Cummins Gearing
Discussion in 'Downeast Engine Room' started by joelucci33, Mar 9, 2012.
  1. joelucci33
    joelucci33 Senior Member
    204
    24
    Manufacturer/Screenprinter
    Merrimac Valley, MA
    Whats the best reduction ratio and Wheel size for a 35 low shear Duffy with a 400HP C-Series Cummins?
  2. GoodChance
    GoodChance Senior Member
    Sep 18, 2011
    174
    16
    SW Florida
    Most guys are using 2:1. Some will use 2.5:1
  3. joelucci33
    204
    24
    Merrimac Valley, MA
    24" or 28" wheel? Typically whats the max wheel size the 35 Duffys will allow? Also what a "safe" Shaft diameter for that engine?
  4. tunafishhkg
    tunafishhkg Senior Member
    Oct 13, 2011
    468
    115
    Cape Cod MA/Hong Kong SAR
    35 Duffy
    If you already have an AQ22 1 3/4 shaft then ok but if you are going new than I would go with a 2" shaft. At 400HP 2-1 you could be in the 26X22-23 I have a 26X26 with 2-1 450 Volvo in my 35 Duffy
  5. TRUE NORTH
    TRUE NORTH Member
    Jan 26, 2012
    34
    Lobsterman
    Spruce Head Maine
    BHM 36/8.1 375 John Deere
    my friend has a 35 duffy, high shear, with a 5.9 260 cummins with a 2:1 and a 1 3/4 shaft and he swings a 26x26 and gets 16/17 knots WOT
  6. Regina E
    Regina E Senior Member
    Feb 8, 2012
    307
    103
    Rockaway Park, New York
    35 Duffy #300
    I have the high shear model with the C8.3 450 HP. The wheel is a 5 blade 26x27 on a 2' shaft although I'd like to add 50 to 100 rpms at wot.
    I'm sure Larry will chime in.
  7. captainlarry84
    captainlarry84 Captain
    1,295
    225
    retired
    The Big Choice!
    We need to know a little more information. However the best diameter wheel for the 35 Duffy is a four bladed 26 propeller. Pitch to be determined based on the RPM range of the motor.
    If the WOT is 2200 to 2400 a 1.77 gear
    If the WOT is 2600-2800 a 2:00 gear
    In either case a 2 shaft is HIGHLY recommended for a wheel that size.
  8. Nighthawk
    Nighthawk Senior Member
    Feb 11, 2012
    119
    16
    Portsmouth, RI
    Carolina Classic
    Not to de-rail the OP's question but I would like to know if the 8.3 QSC engine fits in a 35 Duffy without a step up or engine box?
  9. lobstercatcher
    lobstercatcher Captain
    Dec 13, 2011
    1,306
    196
    ..........No.........
  10. Frank Grimes
    Frank Grimes Captain
    Dec 20, 2011
    1,181
    336
    N41°41'46.91" W070°15'35.13"
    I don't think any diesel over 200 or so HP would fit under the deck of a 35' Duffy without a step or a box. Maybe one of the small Yanmars?
  11. lobstercatcher
    Dec 13, 2011
    1,306
    196
    Mine does but I used a dry exhaust so I have a engine box just for the exhaust. But it is 200hp as you say.
  12. traditions
    traditions Captain
    Oct 9, 2011
    1,006
    214
    38 Holland
    It may not go under the deck,but I have seen 3208's ahead of the bulkhead,so theres no engine box.
  13. MBILL
    MBILL Senior Member
    Sep 2, 2011
    232
    40
    Retired
    35 Duffy&Duffy
    I'm in the process of repowering my 35 Duffy with a 550HP QSC right now so I can tell you surely that a QSC won't fit in a Duffy without a step up or box.
    Here's a photo of the QSC Cummins in the boat. After this shot was taken the water inlet on the exhaust elbow was modified to move more it to the side. The engine just fits under the hatches.
    I don't have the exact measurement of my step up here but I'd guess it's about 6". Here's another photo of that...
    MBILL
  14. captainlarry84
    1,295
    225
    retired
    Repowers & gearing
    Pushing the motor ahead of the bulkhead is to achieve more deck space for work gear. Also when the motor is put that far forward larger motors fit. The big issue on all of these repowers is getting the transmission to clear the wineglass of the keel. The problem with putting the motor that far forward is a loss of speed do to lack of bow lift. The key of these types of vessels in addition to the correct gearing is placing the motors a little more aft.
    On Bills second photo it shows a step on a second Duffy repower. The original plan was a C-9 CAT However it would not fit under the step up so he drop down to a C-7 CAT.
    Back to the gear issue. On Bills 550 repower he had a 3208 450 HP with a 2:0 gear it looks like he will swing the same wheel but with a 1:77! That will be a nice jump in speed. In addition even though HP is increasing because he will just be spinning the same wheel faster the 2 shafting will be more that enough. A lot of though when into doing this repower & I am sure the results will be very impressive.
    More pics Please!!
  15. Downeaster
    Downeaster Senior Member
    229
    13
    Jonesport USA
    A couple of points:
    1. There aren't many new builds (of current designs) where the engine is installed forward of the main bulkhead (though there are builders who can push the main bulkhead forward thus allowing for a similar outcome - Crowley Beal has done this when asked). Glenn Holland's 32 could be an exception. Another downside is fishing the rips - one can get into a real mess in the blink of an eye with this weight forward bias.
    2. Based on many of the posts that I've seen here it will come as a surprise to many that shaft diameter is more the result of wheel size than engine output.
  16. Nighthawk
    Feb 11, 2012
    119
    16
    Portsmouth, RI
    Carolina Classic
    MBill- thanks, that is exactly what I was looking for. With the step up do you happen to know your salon headroom? I am trying to get a feel for what is a comfortable headroom for a 6' person. A boat for example with 6'8" now and no step in my mind could be stepped a bit to dump the engine box. I need about 4" and wonder if 6'4" is too low. Thanks
  17. tunafishhkg
    Oct 13, 2011
    468
    115
    35 Duffy
    On my 35 with no mods to the standard molded top, I have 6 1" in the courners with a 6" total so lets say 5" in engine room.
  18. Hurdy Gurdy
    Hurdy Gurdy Senior Member
    Sep 30, 2011
    197
    65
    BERMUDA!
    This is interesting to read.My Duffy had a 240 perkins with a borge warner 7000 series gear.She swung a 26x24 on a 1 3/4 shaft.I am repowering her with a Cummins 450 c series engine.Still need a gear though.really dont want to up the shaft size.Would a 1 3/4 to 1 gear be ok?
  19. F/V First Team
    F/V First Team Captain
    5,966
    2,262
    Shouldn't have to change shaft diameters at all, 1.75" shafts can take some real abuse. 1.75:1 gear reductions are fantastic, I would recommend a ZF product on the end of that Cummins personally.
  20. Hurdy Gurdy
    Sep 30, 2011
    197
    65
    BERMUDA!
    Thats where Im headed as far as gears go ZF seems like the right move.Does anyone know what a Duffy weighs?Just the hull and top?
