Airmar M260 transducer.
Discussion in 'Marine Electrical / Electronics' started by BHC.com, Jul 11, 2018.
  1. BHC.com
    BHC.com Member
    Aug 8, 2017
    63
    Anyone installed the M260 (yellow plastic box shoot through)
    After the obvious cut bottom of box to fit deadrise, sand/grind/ prep hull & box.....
    Bead of 5200 to glue down & seal box to hull, glass box to the hull or both ???
  2. Old Mud
    Old Mud Captain
    3,243
    2,443
    Retired Fisherman
    I have installed them with just 5200 and they came out great. Of coarse you need a good scribe and fit to make it right. Nothing worse than Oil leaking in your bilge.
  3. cb34
    cb34 Captain
    Oct 31, 2011
    921
    197
    Where is the oil coming from? I have same ducer bedded it with epoxy. Fill box with the pink stuff.......
    cb34,
  4. aegus15
    aegus15 Senior Member
    Feb 8, 2014
    134
    39
    Buzzards Bay
    35 Duffy / 27 albemarle
    I also just used 5200 , no leaks and filled with the recommended antifreeze, the transducer element gets extremely HOT, make sure you have no leaks after you 5200 it down. Just an FYI. From experience.....
  5. Old Mud
    Old Mud Captain
    3,243
    2,443
    Retired Fisherman
    I use Mineral spirits that's what Airmar suggested.
  6. aegus15
    Feb 8, 2014
    134
    39
    Buzzards Bay
    OR, non toxic propylene glycol,.... Antifreeze/ Coolant, .......as installation manual recommends.....not knocking mineral spirits but element gets Extremely HOT
    Old Mud likes this.
  7. Old Mud
    Old Mud Captain
    3,243
    2,443
    Retired Fisherman
    Yes, I was working with support from them as my installation manual was in another state. :)
  8. greg
    greg Captain
    Sep 3, 2011
    985
    197
    Point Judith, RI
    Airmar changed their rec away from mineral oil to pink antifreeze years ago. Note, mineral oil will dissolve 5200 over time. Don't mix them.
    Better method is epoxy and pink antifreeze. That is airmar's current rec.
    greg,
    Old Mud likes this.
  9. BHC.com
    BHC.com Member
    Aug 8, 2017
    63
    Thoughts of using six 10 epoxy from the caulking gun cartridge?
    Prep it like you were going to glass it (grind both surfaces, wash with acetone)
    Big bead on bottom surface of plastic tank, set in place, let excess ooze out, rounder cake tool or 1 inch wide brush to shape excess, both inside & out ???
    Thoughts
    Obviously scribing/cutting tank to hull angles and deadrise is key for a good seal.
