Alternator Cable Size?
Discussion in 'Marine Electrical / Electronics' started by ArchHibb, May 25, 2018.
  1. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    633
    446
    Architect
    Marblehead
    Five Islands 35 w/Cat 3116
    I searched, but didn't find an answer.
    I discovered the cable between my alternator and the battery charging system has developed corrosion and consequently melted the jacket at the alternator connection. It's a 2 AWG marine cable, CAT 3116, standard-output alternator I believe.
    Should I replace in-like-kind or upsize? Any advice appreciated!
  2. Lobster.mike
    Lobster.mike Senior Member
    Nov 1, 2015
    311
    90
    I'm no electrical wizard but it sure seems big enough. Was there any kink or loose connection before it melted?
    Keelboater and Genius like this.
  3. Keelboater
    Keelboater Captain
    4,138
    2,028
    Clinton Harbor & North Cove
    If it's long enough, cut it back past the corrosion and see how it looks. If it's good, put a new terminal on it and some heat shrink tube.
    captjohn likes this.
  4. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    633
    446
    Architect
    Marblehead
    No kink, but I did discover the terminal stud on the alternator had some black material caked around it. My best guess is that it was belt dust that accumulated over time and started to degrade the electrical connection. Once started, heat build up could become an issue and then the cable jacket degrades. Salt air corrodes the exposed copper... you see where this is headed.
  5. BlueMack
    BlueMack Senior Member
    Oct 14, 2014
    409
    145
    New Hampshire
    Bruno & Stillman 35
    2 awg is plenty big enough, my question is, is that marine wire or welding cable? The first picture, the strands look too fine to be marine wire, looks more like welding cable.
    Diesel Jerry likes this.
  6. powderpro
    powderpro Captain
    Dec 3, 2011
    2,648
    1,538
    The Ocean
    O'Neil
    I also have 2 gauge on my new 6.8L Deere, I would say you're good to go with the size wire you have.
  7. Kodiakan
    Kodiakan Senior Member
    Aug 26, 2013
    469
    99
    I'd replace it but that's just me. When one end fails who knows what is under the insulation. I've seen a lot of wires that look fine on the outside but had rotten spots.
  8. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    633
    446
    Architect
    Marblehead
    Thanks to everyone for the replies. I replaced it with a new 2 AWG marine battery cable from Ancor and will try to find or make a dust shield for the terminal connection.
    BlueMack and Kodiakan like this.
  9. Toolate
    Toolate Captain
    5,184
    1,375
    Building contractor
    I have what looks to be the same alt and its output is 105A and mine is wired with 2/0 also.
  10. TCL
    TCL Senior Member
    Jan 29, 2014
    273
    65
    Sabre 36 The Captain's Lady
    Are you sure that the nut at the alternator fitting didn't come loose? That could cause heat, but just the presence of belt dust unless it was between the faces of the fitting would not cause heat.
    I had a similar problem on a battery terminal that was a little loose.
    TCL,
    Kodiakan and Genius like this.
  11. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    633
    446
    Architect
    Marblehead
    Yes, the nut & washers were tight, but all the threads on the terminal, save those covered by the nut, were full of black which I suspect was belt dust. So the cable to terminal contact was definitely compromised.
    I’ll keep an eye on it and see how it goes.
  12. Genius
    1,718
    656
    was the nut a nylock?
  13. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    633
    446
    Architect
    Marblehead
    It is now. Regular nut on there had lock washer but was incorrect size; a bit too big. Found a new correct size nut, but only available in stainless as a nylock.
  14. Genius
    1,718
    656
    I'd suggest you go back to a regular nut and lock washer. I've only had problems with nylocks on terminal connections. I really don't have a theory on it, just bad luck.
    ArchHibb likes this.
  15. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    633
    446
    Architect
    Marblehead
    Had a feeling you were going to say that... :confused:
    Cat used a reg. nut & lock washer, so that’s what I’ll use too.
  16. captjohn
    captjohn Captain
    Apr 12, 2013
    503
    137
    Seaford, NY
    Henriques
    Corrosion, or a loose connection, causes resistance in the wire, and a voltage drop. The resistance results in localized heating of the affected area, if bad enough, yea, it'll melt the insulation. Replacing the wire really is the best answer. Make sure the crimps on the wire ends are nice and tight, or you'll be back where you started from. A mechanic showed me years ago a really simple way to test a wire that you suspect is bad. Using an old fashioned test light, connect it at both ends of the suspect wire. A wire with no resistance in it will have no voltage drop across it, and the light will not come on at all, indicating that the wire is good. But if the wire has resistance in it, resulting in a voltage drop, the light will start to glow, indicating that it is no good and must be replaced.
