Attaching outboard bracket to transom
Discussion in '"Pocket" Downeast Boats (14-24ft)' started by jdickau484, Feb 7, 2018.
  1. jdickau484
    jdickau484 Senior Member
    Nov 25, 2012
    315
    255
    Ninigret Pond, RI
    On Friday I got the 6 platform bolts drilled out and tightened up and I.T gave me a better idea of how the bracket would fit when tighten to the hull. Turned out the platform edges didn’t seem to be any issue at all but the main portion of the bracket had a decent gap. Which actually made the gap easier to fill, just built up the area with layers of glass and I.T did the trick. I appreciate the discussion and help along the way.
    Toolate likes this.
  2. kcassells
    kcassells Senior Member
    Jan 10, 2015
    117
    19
    Phila Master Plumber
    Pa
    Nice result!
  3. Toolate
    Toolate Captain
    4,942
    1,271
    Building contractor
    I am still paranoid about the transom/deck/stringer connection on the inside of the boat. I think I would be thinking about a reinforcing brace from each stringer up through the deck to the transom. Like a triangle of coosa maybe 16”x16” glassed on top of each stringer and to the transom. Again “paranoid” is the word I use because it could be for nothing- hoping some one will comment.
    This came out great! Nice works :)
  4. kcassells
    Jan 10, 2015
    117
    19
    Pa
    yea it's the foam board that gets ya thinking in regards to compression and weight.
    I've never seen anyone bring knee braces up above the floor like that for add'l support though.
    My ten cents is on the new glass pad. I might even recommend calling the foam board mfg and or the transom bracket mfg with the set up build up/construction of the transom just for letting me get to sleep at night. Might even come under a warranty issue if there were problems down the line.
    Yup got me overthinking it. I've seen these done everyday {with an all wood transom} but the foam has me just wondering to much.
