awlgrip or other paint
Discussion in 'Downeast Projects and Boat Building' started by 05bill, Dec 7, 2017.
  1. 05bill
    05bill Senior Member
    Oct 10, 2011
    475
    63
    cape cod
    rp, willis beal
    Cam any ome recommend a hull paint for durability repair ease of application and lasting ability ?
    And how much a ft to have it applied ?
    I know it will vary by location but this will be done in Maine .
    Thank you
  2. offshore27ns
    offshore27ns Senior Member
    Dec 17, 2011
    315
    209
    Chester, Nova Scotia
    Wesmac
    Iwould reccomend Alexseal
  3. Henfruit
    Henfruit Senior Member
    Aug 22, 2016
    259
    94
    SC winter Deer Isle Summer
    Samson 30
    guess $ 200.00 a foot
    Calheat likes this.
  4. 05bill
    Oct 10, 2011
    475
    63
    cape cod
    rp, willis beal
    Thank you. Too cheap to pay 200 per ft.
  5. Blitzen
    Blitzen Captain
    3,060
    1,514
    Ex Merchant Marine
    36 Flowers and a 1991 Boston Whaler Outrage 19
    If you do have it done go with AwlCraft by AwlGrip. It will be the easiest to repair or blend when the time comes.
    Check with Onset Bay Marina a friend of mine (Greg) is the manager there and may provide you with a good quote.
    Beyond Tom's likes this.
  6. Bill
    Bill Administrator
    3,097
    1,987
    Crow Point, Ma
    27 Terry Jason / 21 Repco
    Ive used Interlux perfection 3 times just rolling it on with a foam roller from lowes.. just the ones for cabinets and doors.. just roll it on in about 60 degree weather. use the primer they recommend.. I dont tip it just roll on the first 2-3 coats, sand it down with 300 grit or so then last coat roll it and use another dry roller to barely flatten it out.. its not perfect but i dont fell bad when i knick it up etc .. wholesalemarine.com has best price on it usually with free shipping
    Bill,
    ErikT, Kenneth, leaky and 2 others like this.
  7. c1steve
    c1steve Senior Member
    Jan 30, 2017
    179
    24
    I have used Awlgrip on many projects. The gloss lasts an incredible amount of time. However for a deck it is slippery and needs nonskid additive. I have tried to roll and tip it on, but not had much success. I know it can be done, and it looks great when properly applied by roll and tip.
    Usually I have sprayed Awlgrip, which is fairly easy to do. It sprays easy, looks great, but you HAVE TO wait 30 minutes between coats. Otherwise it will run terribly. If you have the patience to wait the 30 minutes, the spray process is easy. Be sure to add Awlgrip accelerator unless it is really hot out.
    Bill likes this.
  8. 05bill
    Oct 10, 2011
    475
    63
    cape cod
    rp, willis beal
    Thank you all great information. Very helpful and I will call Greg.
    Again thank you all.
  9. Brooksie
    Brooksie Captain
    Mar 25, 2013
    1,134
    341
    Talking roll and tip here not spray:
    I have always had good luck with International Perfection and International PrimeKoat (both use the same thinner). IMHO much easier than AwlGrip and seems to retain gloss better. That said, 2pk poly's are not easy like enamel or 1pk poly but the results are worth it You must pay attention to the film thickness and add reducer as you go along. Even stopping to move your ladder can cause you to loose your wet edge so a helper is in order.
    BTW, don't even think about Pettit's 2pk, it's not ready for prime time by any means and they don't seem to have a good epoxy primer to go under it either. How do I know? I've got a 34' boat waiting for a free repaint b/c the owner chose a color from Pettit and we tried to use it.
    CRABBYPATTI likes this.
  10. Charlotte
    Charlotte Member
    Oct 8, 2017
    17
    6
    Both Awlcraft and Alexseal are repairable. I would recommend you find the yard and then use the product they are most comfortable with.
  11. c1steve
    Jan 30, 2017
    179
    24
    Painting over wet epoxy always results in low gloss LPU. I do it to obtain the best bond, but wet sand the first coat of LPU and then apply a second coat. When topcoating dry epoxy, I just sand appropriately and it has always worked well. Usually the epoxy was DeVoe Bar-Rus, but also Interlux epoxy has not been a problem.
  12. Beyond Tom's
    Beyond Tom's Senior Member
    Apr 28, 2013
    488
    356
    Electrician
    Oceanside NY
    31 JC
    Beautiful job bill
    Bill likes this.
  13. Beyond Tom's
    Apr 28, 2013
    488
    356
    Electrician
    Oceanside NY
    31 JC
    I second that Blitzen, I’ve made a few changes on my transom with the muffler after she was painted and had the marina touch them up and you can’t even tell. Now with the trim tab project I’m going to need them to spray some more and not worried. Awlcraft in my opinion is the way to go.
  14. CEShawn
    CEShawn Captain
    Sep 21, 2011
    2,867
    851
    RP35
    I tried Quantum for the first time this year. I sort of liked it and now that I know a little about the learning curve, want to go back and try it again. Something I liked about how it mixed and laid out. I think I was a little more unhappy with my prep work which I know is so much. I also think gloss green wasnt the way to go. I really really liked the grey primer, alot... enough that wife liked it and thinking about the switch...
  15. MBILL
    MBILL Senior Member
    Sep 2, 2011
    233
    41
    Retired
    35 Duffy&Duffy
    I used Awlcraft 2000 a few years ago and it still looks great. I'll see if I can find an invoice with the cost....
    The only downside is that it doesn't work well in locations that are always wet, for instance where you've got a cooler or a container of sinkers sitting on the deck all the time. The paint will bubble over time in this situation.
    I had a lot of trouble keeping it in shape on my steering hatch which has cups for the handle. I found that Interlux bilge coat works great for that problem.
  16. leaky
    leaky Captain
    Sep 9, 2014
    1,765
    529
    Good stuff Bill. When I was at Holland's shop awhile ago they were doing similar work with an Epifanes product with similarly great results. I couldn't believe it when they said all they did was roll it on.
    Funny what you said how you do the first 2 to 3 coats different from the last. I pulled my hair out a few years ago following directions of no primer, thinning, roll & tip, then wet sand between each coat, with a cheap single part paint. After about my 3rd coat of that nonsense I realized if you going to sand you ought to have something to sand into. Later figured out how much better the good paint works.
    Jon
  17. Game fisherman
    Game fisherman Senior Member
    Oct 13, 2013
    153
    152
    Boat builder / Firefighter
    South shore ma
    35 Duffy low shear
    Alexseal is all I use painted a Boat 8 years ago and it still looks like gelcoat. You can repair it and sand and buff it .
    Bill likes this.
  18. WoundUpMarine
    WoundUpMarine Captain
    2,576
    1,001
    Boothbay, Maine
    34 Libby, 14 Holland
    Bill, How long do you wait between coats when doing the first 2-3 coats?
  19. Bill
    Bill Administrator
    3,097
    1,987
    Crow Point, Ma
    thanks Jon. The primer is good strong stuff and will fill in pin holes etc. you don’t have to be too careful with it just get it on the boat . 2 part is the way to go for me. I tried one part and hated it. There is a guy on THT that did his boat with rustoleum and made it look like a mirror claims it’s hsrd as nails . But way more work. The perfection you can sand down quick a few years later and just add another coat .
    John , you can apply another coat within a certain amount of hours I forget . They say for best results sand in between coats for best results but like Jon said you gotta get paint on the boat . It doesn’t have to be pretty and you can practice on the first coats which will be sanded down at the end then by the time it’s ready for 3rdor 4th you are good at the method .
    Key is to keep the wet edge going . I’m a lefty so I start on port side bow and work my way back and around the boat .. it’s easier on a small boat but when on a big tall boat you gotta move quick or that edge sets up quick. Anything over 70 degrees I found sucked. Paint just flashes too quick
    Bill,
  20. November Rain
    November Rain Senior Member
    Mar 22, 2012
    298
    240
    Montauk, New York
    43' Lowell
    We had to repair a crack on the roof last year, everything came out well, execpt blending in the Awlgrip. There is a raised line going across the roof where the new paint went on over the old paint. If we sand it smooth, it will be a dull/flat spot. Just my two cents.
