Bow Swivel Rod Holder
Discussion in 'Tuna Talk' started by SYo, Apr 4, 2018.
  1. Old Mud
    Old Mud Captain
    3,424
    2,598
    Retired Fisherman
    Rob did you build your gin pole yet ?
  2. leaky
    leaky Captain
    Sep 9, 2014
    1,799
    553
    Don't waste your $$ or make this complicated - there are a zillion sellers of this model, $25 on this Ebay listing but usually they are more like < $20 if you shop around a bit. Last season I bought two for $38/shipped.
    2 Ton Rope Hoist Pulley Wheel Block and Tackle 4 000lb Wild Game Deer Hanger | eBay
    Sure in a big boat where you can have an electric winch mounted well, covered well, kept in good order, then I guess you can do it with one of those more easily - but in a small boat with some temporary mounted thing in the end it's going to be more difficult.
    Whatever you do make sure you over-size it with an electric - I doubt a $50 one is gonna do it well, ratings for electric winches are usually based on the rolling load they can handle not what they can lift and the last thing you want is an electric winch that struggles.
    By myself I've lifted a number of 400 lb fish into the boat using these cheap 4 over 4 block & tackles, and we've lifted them up to > 900 lbs, which I probably could still do myself. It's not hard, nor do you need anything else. They will rust over time, does not hurt anything really, but when they get crusty just buy a new one - I always have a spare. Don't ask me what wennow means - obviously made in China :).
  3. SYo
    SYo Member
    Jul 10, 2016
    83
    28
    Maine
    28' Wayne Beal
    I’m glad someone asked about the pulleys. This new pole looks a little bare without one.
    SYo,
  4. Old Mud
    Old Mud Captain
    3,424
    2,598
    Retired Fisherman
    Leaky that 2000# is a rolling load but i have picked fish up to 745# with mine. The only reason i used one of those is i use them and the 2500# ones for putting in floats and ramps. The thing you have to do is drop all the wire off and save just what will reach the water. Much more torque down near the core.
    Mine is on a small boat, if it were on a bigger boat i would be using a door. 4" Sch. 40 with all the mounts through welded.
    Mounts at the deck, at the wash rail and at the top frame. I also get to mount my Morad and poons.
    Works for me. :)
  5. 30-06guy
    30-06guy Senior Member
    Apr 25, 2017
    105
    29
    Not yet. Life kind of got busy the last couple of weeks. I'm hoping next week or so to get on it. I will start a new thread when I do. I have been keeping an eye on this one though and getting some ideas.
    Rob
  6. bassriver
    bassriver Member
    Mar 1, 2012
    57
    Don, appreciate the suggestion, I will check them out. Hope all is well, Steve
    Old Mud likes this.
  7. Billyclub
    Billyclub Senior Member
    Apr 7, 2013
    173
    17
    Scarborough, Maine
    Yes, it is the one from Browns.
  8. tuna_fan
    tuna_fan Captain
    Mar 22, 2012
    512
    147
    Gloucester, MA
    Nice - that was my father's boat. Nice to see someone getting some use out of it and throwing some tuna on !
  9. Bobby
    Bobby Member
    May 2, 2018
    I fix stuff & Fisherman
    Southern ME, (this year)
    I love the idea of removing the extra cable to get more torque. I have a Parker Sport Cabin with an outboard (hope that is okay on this site, I'm a DE wannabee, maybe next year). I use a 2000# warn winch, I mount it to my horizontal davit on my roof using U-bolts so I can easily remove and store, I made a removable ramp (2 rails) that I attach between the stern and the bracket, then I pull right over the stern, not lifting the fish out of the air. On a 600#+ last year I was blowing fuses, so I added another pulley with a hook that basically cuts the load in half, then no problems.
  10. Billyclub
    Apr 7, 2013
    173
    17
    Scarborough, Maine
    I built my gin pole 9' and would have gone taller if I had the room to store it. I would go at least 10'. By the time you factor in the fish length and block and tackle you will use all of that height. I lift them head first and get the heaviest part of the fish high, it is much easier swinging in the tail vs. the head. I also like to gut them while hanging as the vent tends to pull down or relax after you cut the cords. I would recommend double sleeving the halves if you plan on making a two piece set up.
    Old Mud likes this.
  11. Billyclub
    Apr 7, 2013
    173
    17
    Scarborough, Maine
    Did he use it much and did he purchase the Johnsons in 1998? Just trying to estimate the hours that were on the outboards when I bought them
  12. tuna_fan
    tuna_fan Captain
    Mar 22, 2012
    512
    147
    Gloucester, MA
    barely ever used it, it was a harbor/beach boat...and he was not the original owner. boat came with the engines when he bought it.
  13. Cookie
    Cookie Member
    Dec 8, 2011
    66
    Northern Bay
  14. Yesac13
    Yesac13 Member
    Mar 15, 2018
    56
    23
    Careful with that one... I have one exactly the same model. I know it's the same because of the looks (everything, down to the rope, the nice rubber stopper, etc) plus the ad copy for it...
    The plastic sheaves split while lifting 90-100 LBS. I couldn't believe it, it is that trashy. Lifting 400 LBS or so gives me a severe case of the heebie jeebies. Anyway, if it suddenly jams, look at the sheaves. Mine is now useless and I keep meaning to find new sheaves for it - won't buy another new one period, how can I trust the sheaves? I'm a sailboater and also move stuff with blocks... never never saw a split sheave til this one! With new sheaves it would be better than new. The grade of the plastic for these sheaves just was too crappy. Be forewarned.
