Engine compartment soundproofing
Discussion in 'Downeast Engine Room' started by Jonathan Carey, Mar 25, 2018.
  1. Jonathan Carey
    Jonathan Carey Member
    Mar 14, 2018
    6
    Looking for recommendations on sound proofing for engine compartment. Thanks in advance!
  2. xbskt
    xbskt Captain
    1,415
    1,086
    electrician
    28 Crowley Beal
  3. crabz
    crabz Senior Member
    Nov 2, 2015
    344
    113
    commercial fisherman
    Alaska
    All American
  4. Genius
    1,920
    769
    I believe first level of attack is closing all gaps that let sound out. Also gaskets on engine hatches, etc. Then sounddown panels to bulkheads and engine room overhead/hatches. Others also use carpeting/mats and or underlayment atop the engine area to control sound.
    chortle likes this.
  5. Toolate
    Toolate Captain
    5,333
    1,439
    Building contractor
    Anyone have a source for a good, thick gasket that is maybe 1/2” x 1 1/4” medium density, closed cell, adhesive backed?
  6. Gurryman
    Gurryman Captain
    Sep 6, 2012
    961
    510
    New Bedford MA
    Nauset 28, CuttyHunk 28 Molds
    Rubber Seal Material, 3 types
  7. Toolate
    Toolate Captain
    5,333
    1,439
    Building contractor
    Looks like it might be too thick for me. Is it adhesive backed or just get some double sided tape?
  8. Gurryman
    Gurryman Captain
    Sep 6, 2012
    961
    510
    New Bedford MA
    No adhesive, I used to use a water based 2 part epoxy made by Lord Chemical.
  9. nick5446
    nick5446 Member
    Aug 26, 2015
    90
    17
    Hi - working on a similar project and someone suggested a 2 part expanding foam for insulation. Anyone know if this would hold up to the heat of an engine? I can't find anything online.
  10. TAftw
    TAftw Senior Member
    May 31, 2015
    163
    54
    RI, Cape and Islands
    That stuff is probably extremely flammable. I don’t think that would be the best option for soundproofing in an engine companrtment.
  11. Dr. Chip
    Dr. Chip Senior Member
    Nov 7, 2013
    384
    164
    Professor and Director
    New York
    Bruno & Stillman 35
    This place has a dizzying array of stuff..
    D-Profile Sponge Rubber Seals
    Toolate likes this.
  12. cg_Duffy
    cg_Duffy Member
    Jun 23, 2016
    Engineer
    Second on the soundown. 2" thick, 2lb / ft^2.
    Seal all hatches with foam tape; available with adhesive in every possible width, thickness and density one could ever want from McMaster Carr. Pack all cable conduits with foam.
    No exhaust hangers connected to floor.
    If you really want to get after it, more Soundown 2lb/ft^2 carpet underlayment on top.
    While not absolutely precise, there are decent apps for iphones that measure sound pressure levels so you can get a fell for progress you are making; or not.
