Engine Won't Shut Down
Discussion in 'Downeast Engine Room' started by MacDuff, Jul 2, 2018.
  1. MacDuff
    MacDuff Member
    Mar 11, 2018
    22
    14
    Couldn't shut down my Volvo TAMD40B this afternoon. Had to plug the air intake to turn it off. Anybody have thoughts on this? I suspect the switch.
  2. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    3,426
    1,640
    Did you try turning the key back the other way one click?
    With the engine off have someone move the key switch while you listen to the stop solenoid.
  3. MacDuff
    MacDuff Member
    Mar 11, 2018
    22
    14
    Yes, I tried one click the other way. Then tried the flybridge switch. Was by myself. I'll check the solenoid when I have someone with me. Thanks
  4. Diesel Jerry
    Oct 25, 2015
    3,426
    1,640
    I can't remember if those are power to stop or remove power to stop.
  5. fortier256
    fortier256 Captain
    Feb 10, 2013
    505
    161
    Narragansett Bay
    Fortier 26
    No Volvo experience but I would be staring down by the injection pump looking for corroded wires or a relay / solenoid with dirty connectors.
  6. Skeetsdad
    Skeetsdad Senior Member
    Apr 10, 2016
    170
    95
    Scituate MA
    28 Carolina Classic, 34 Webbers Cove
    It used to happen on my Volvo 41A about 20% of the time. there is a spring loaded plunger on the fuel pump. Push it in and it shuts off the engine. It does what the "shut off solenoid" is supposed to do.. No need to starve the engine for fuel or air. I learned the hard way..googled it on my phone when engine wouldnt shut off. Its not on the lift pump, its on the BOSCH injector pump. Wish I saved the picture of it.
    MacDuff likes this.
  7. MacDuff
    MacDuff Member
    Mar 11, 2018
    22
    14
    As usual, great stuff! Thanks All.
    Skeets- You sell your CD 28 yet?
  8. Skeetsdad
    Apr 10, 2016
    170
    95
    Scituate MA
    Yes, sold her in the spring. Nice couple from RI. No dickering just, "yup, Ill take her".. He knew Cape Dory's so we didnt need to do a sea trial. And I did show him how to shut her down at the injector pump if the stop solenoid doesnt work. That solenoid was probably the one thing I didnt address on that engine. I would open the hatch to check the engine at the end of the day when I shut down so reaching over to push that lever was no big deal. I think the solenoid was $700, but easy to find..
  9. willbfishin
    willbfishin Senior Member
    Oct 2, 2014
    231
    92
    My stop solenoid burnt up twice on same engine
    If the key is left on by accident they burn up
    At least mine did
  10. Ditchdigger
    Ditchdigger Captain
    Feb 19, 2012
    702
    364
    What Skeets dad said. Push the plunger down on top of the injector pump. Have a TAMD 60 series. Happens every once in a while. Usually when there is very low water in the slip, and I kicked up a lot of mud and want to shut the motor off as quickly as possible as to not suck up the mud in to the sea strainer. Or when I'm winterizing the boat on land, and I have just sucked up the last gallon of the pink stuff.
  11. goody
    goody Senior Member
    Feb 3, 2013
    232
    219
    Merchant Marine
    Forked River,N.J.
    Ellis 28 and Tripp Angler 22 C/C
    I just looked on my 41a didn't see it if someone can post a picture would be great to know where to shutdown engine thanks have a good 4th
  12. MacDuff
    MacDuff Member
    Mar 11, 2018
    22
    14
    Classic!
  13. goody
    goody Senior Member
    Feb 3, 2013
    232
    219
    Merchant Marine
    Forked River,N.J.
    A picture would help just looked again I don't see it
  14. Skeetsdad
    Apr 10, 2016
    170
    95
    Scituate MA
    Goody, Let me qualify by saying Im no mechanic... but this worked for me for a long time. I dont have a picture of the injector pump on my boat (sold) so I googled it. This is an injector pump for a TAMD41A. Its mounted on the engine in the same orientation in the picture. You can see that little lever (in the center) that pivots.... I recall mine had a spring on the bottom. ON MINE, when I pushed the bottom of that little lever (aft), the engine shut down immediately. IMG_1186.JPG
  15. the_Bartender
    the_Bartender Member
    Jan 20, 2017
    93
    50
    Former Merchant Mariner, Now Commercial Fishing
    Lower Chesapeake Bay/Atlantic Ocean
    35 Bruno
    This is the kind of problem a decent reliable Bowden Cable would remedy. The cost would be more like $15 >$20 instead of $700. I admit I don't know this particular engine but a bowden cable was a standard emergency shut down feature on several engines in the past.
  16. goody
    goody Senior Member
    Feb 3, 2013
    232
    219
    Merchant Marine
    Forked River,N.J.
    Thank you I'll check it out when I get home
  17. yanmar
    yanmar Captain
    Aug 31, 2011
    846
    939
    Forked River, N.J. USA
    26 chesepeake 22 tripp
    Must be power to activate .
  18. goody
    goody Senior Member
    Feb 3, 2013
    232
    219
    Merchant Marine
    Forked River,N.J.
    Thanks Skeetsdad found it I tried it works easy enough to put a emergency cable on thanks again
    Skeetsdad and Keelboater like this.
  19. steveinak
    steveinak Captain
    4,315
    1,709
    H&H / Pen Bay
    Some 550 heading twine with a ring on the end would work just fine. Buddy used to have that with the ring sticking out of the engine box.
  20. MacDuff
    MacDuff Member
    Mar 11, 2018
    22
    14
    Fixed! Terminal corroded. Thanks everybody!
    goody likes this.
