I want to make a new wheelhouse/pilot house and can use help with materials
Discussion in 'Downeast Projects and Boat Building' started by morichesfisherman27, Dec 19, 2015.
  1. Keelboater
    Keelboater Captain
    4,194
    2,075
    There always is!
  2. morichesfisherman27
    morichesfisherman27 Captain
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    I want to level the boat from bow to stern before I start making my sides to the wheelhouse. is it as easy as putting a jack under the bow and just having a couple buddies raise the adjustable stands as I go? the bow needs to be lifted about 4 or 5 inches id say to get the waterline level.
    my next option. That I think is the way to go,is call the guys that transported my boat and layed it up.
    I know its just a couple inches. but the boat is big and intimidating to attempt to lift it up
  3. traditions
    traditions Captain
    Oct 9, 2011
    1,103
    276
    38 Holland
    Make sure you slack up the stern stands before you jack up the bow.
  4. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    so really the weight is going to be staying in the middle of the keel where it is blocked. kind of like a seasaw right? the sterns going to come down as the bow goes up? I was under the impression of just raising the bow
  5. xbskt
    xbskt Captain
    1,309
    989
    electrician
    28 Crowley Beal
    Traditions is right. Also keep in mind that if you have the room under the skeg to lower the stern you only have to raise the bow half that original 4 or 5 inches to get to level.
    Slow and steady.
  6. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    Ok looks like im gonna go for it this weekend. Slow and steady
  7. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    3,367
    1,617
    Depending on how the boat is built you can change dimensions of a boat my not properly setting the jackstands. Take some string for and act and port to starboard and make sure when your done all your strings are under the same tension as when you started.
  8. ed lorence
    ed lorence Member
    Jan 29, 2016
    42
    14
    Remember, the boot stripe is not the water line. The boat was built favoring more weight aft in order to give a better ride like a woman.
  9. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    Im going off the actual waterline thats stained on the hull from the sludge
  10. kcassells
    kcassells Senior Member
    Jan 10, 2015
    260
    48
    Phila Master Plumber
    Pa
    With the new construction/weight changes, I would wait to pint the line.
  11. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    Im not worried about paint. The top of my pilothouse has to be level
  12. ed lorence
    ed lorence Member
    Jan 29, 2016
    42
    14
    If the top of the pilothouse is level, it will appear to pitch forward. Also, the sides should taper inward about 2 or 3 degrees or they will appear to pitch outward.
  13. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    Yea im following the angle on the trunk. The only thing i gotta figure out is the top of the house from bow to stern
  14. ed lorence
    ed lorence Member
    Jan 29, 2016
    42
    14
    It sounds like you're on the right track. Good luck!
  15. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
  16. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    All rotted
  17. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    1EC7E460-C5C1-4E9C-ABA2-77DF752CDC7A.jpeg 699A1BF9-64C3-479F-8791-233843DE86A2.jpeg 4A8EDF8D-FD21-4896-9A45-77FA5FF5A1FA.jpeg 29106022-145D-4482-93EF-E86A161C17AF.jpeg Still have the side to replace. Im going to throw some fiberglass on this piece to stiff n it up before doing the side
    Genius likes this.
  18. ed lorence
    ed lorence Member
    Jan 29, 2016
    42
    14
    When you leave a boat outside and uncovered for TWENTY or more New England winters, this is the result.
  19. morichesfisherman27
    Jan 20, 2015
    532
    145
    East moriches ny
    34 webbers cove
    161B53C6-D4FC-4FD3-B8F5-4951361B428B.jpeg 4F888579-0700-4885-97D8-420BC35B7411.jpeg Keep chipping away at it
  20. ed lorence
    ed lorence Member
    Jan 29, 2016
    42
    14
    That is a major bulkhead. Please use accepted boat building techniques when repairing! I think "Tashmoo 2" still has one of my books on the subject. The triangle patch does not appear to be up to the task.
