John Deere 6076AFM 300 hp. WOT?
Discussion in 'Downeast Engine Room' started by MikesMarine22, Apr 7, 2014.
  1. MikesMarine22
    MikesMarine22 Senior Member
    Oct 21, 2011
    273
    93
    Marine Mechanic
    Mass
    Curious if anyone on here knows the WOT on this engine? Have not been able to find to much info online. And maybe peoples opinions on this engine. Pros and cons..... thanks
  2. petrel
    petrel Captain
    Dec 17, 2011
    1,583
    373
    NC
    56' DMR, 31' BHM
    Did you try the boatdiesel site- lots of engine spec stuff there? Is that the jacket water after-cooled version of the one that was 375hp at 2400 w/ salt water cooling? I'm guessing it's around 2200 or 2300 loaded, but someone around here should know.
  3. MikesMarine22
    Oct 21, 2011
    273
    93
    Marine Mechanic
    Mass
    yes, it is freshwater cooled.
  4. CaptDave
    CaptDave Captain
    776
    262
    U.S. Coast Guard (Civilian)
    2400 is the rated RPM for wide open throttle, have one and have had great lcuk with it.
    Send me your email to captdave@relentlesscharters.com and I may be able to send you some information.
    Dave
  5. CaptDave
    CaptDave Captain
    776
    262
    6076AFM30 PERFORMANCE RATINGS AND OPERATING SPEEDS
    Performance kW (hp) Normal Working Fast Idle Maximum Maximum Full Power
    Rating Range RPM RPM Load Operation Operation***
    (Minimum*—Maximum**) Factor (Hrs/Yr) Per 24 Hours​
    M1 160 (215) 1500—2200 2400 1.0 8760 24
    M2 187 (250) 1500—2200 2400 0.65 3000 16
    M3 224 (300) 1500—2400 2620 0.35 2000 8
    Gen Set 139 (186) or 168 (225) 1500 or 1800**** 1890 0.67 8760 16
    • Slow idle speeds are set at the producing factory at
    750 rpm on all propulsion engines and at 850 rpm on all
    generator set engines.
    • Fast idle speeds are 200 rpm greater than maximum
    full load working range on standard governor engines
    and 90 rpm greater than maximum full load working​
    range on generator set engines (3—5% governor
