Keel modification
Discussion in 'Downeast Projects and Boat Building' started by Henfruit, Nov 13, 2017.
  1. Henfruit
    Henfruit Senior Member
    Aug 22, 2016
    236
    77
    SC winter Deer Isle Summer
    Samson 30
    trying to get more water to the prop. My dead wood is one big water bypass to the prop. The yard and some local lobsterman saw the boat and suggested this idea as they have done it before. We will see how it helps. More water to the prop should help with hull vibration and maybe gain a little more efficiency and speed. Hope to get it done this week and sea trial. One hold back. It is Deer season in Maine
    Ludog and Toolate like this.
  2. Brooksie
    Brooksie Captain
    Mar 25, 2013
    1,046
    302
    I made mine of oak and bolted them on. I think they should be in the center too. I think you will like the change
      File size:
      1.2 MB
      240
      File size:
      1.8 MB
      239
      File size:
      1.7 MB
      241
      File size:
      2 MB
      244
  3. RockBottomFish
    RockBottomFish Senior Member
    Nov 5, 2014
    134
    39
    Montauk
    BHM
    Interesting....
    Any thoughts on doing the same on a 31 BHM. Have no vibration issues, what else would be gained?
    Brooksie, what change did you experience?
  4. ArchHibb
    ArchHibb Senior Member
    Aug 31, 2013
    433
    300
    Architect
    Marblehead
    Five Islands 35 w/Cat 3116
    Subscribed...
  5. Brooksie
    Brooksie Captain
    Mar 25, 2013
    1,046
    302
    I did it so long ago I can't remember exactly how much speed I picked up, but some. Also backing down improved. I had some vibration and had just gone from 3 to 4 blades and thought I had it cured but these "fairing blocks" helped as much as the 4 blade over the three.
  6. Keelboater
    Keelboater Captain
    3,504
    1,489
    I found these under a ton of old bottom paint on my boat. I always thought the keel was shaped that way until the paint was stripped.
  7. Field Tester
    Field Tester Senior Member
    Sep 7, 2011
    276
    117
    Montauk, NY
    I modified mine when I re powered. I went from running a 22" wheel to a 26" along with a ratio change. Boat runs great! Very smooth, no more vibration in the floor above the prop.
  8. Field Tester
    Sep 7, 2011
    276
    117
    Montauk, NY
    A couple more pics.
    Bill and MASTERENEGADE like this.
  9. Toolate
    Toolate Captain
    4,804
    1,207
    Building contractor
    Where is GMAC? His thread was ridiculous (ly good)...
  10. traditions
    traditions Captain
    Oct 9, 2011
    955
    169
    38 Holland
    A previous owner dished out ahead of the stern post on my Novi. They did a nice job, instead of adding fairing blocks, they cut out ahead of the stern post, and filled it in like on field testers boat. the stern post on a Novi must be 8 inches wide. I know of another Novi that had a bad vibration, and fairing blocks took care of the problem.
    Genius likes this.
