1. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    2,998
    1,485
    Come get these off my bench...drop of beer, coffee, donuts, for me and the crew (12-14 and 3 dogs).
    2" inner diameter.
    One is broken.
  2. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    Bump. Brand new these are $500+. I am 1 1/2 to for bashful a kind gesture.
  3. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    If these are not gone soon they will be headed to the dumpster.
  4. TAftw
    TAftw Senior Member
    May 31, 2015
    137
    45
    RI, Cape and Islands
    Where are you located? I might be upgrading to a 2” shaft and could definitely use them
  5. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    South Freeport, Maine. I will Won't be back until Monday. I will be in Rockland, Maine Sunday but that is further away.
  6. HUNTHARD
    HUNTHARD Captain
    Mar 22, 2013
    1,627
    1,170
    Produce Sales.
    Hampton Bays, NY. / RI
    42 WESMAC
    let me know if you come across any for 2.5 inch shaft.
  7. Pitou
    Pitou Senior Member
    Dec 11, 2012
    238
    52
    Real Estate Broker
    Cape Ann
    '06 Albin 31 TE
    Any chance these are still hanging out on your bench? I could use them and need a good excuse to head north .... thanks
  8. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    Yup, Just remember, coffee, donuts, beer, pizza, or whatever for the guys I work with
    Pitou likes this.
  9. Pitou
    Pitou Senior Member
    Dec 11, 2012
    238
    52
    Real Estate Broker
    Cape Ann
    '06 Albin 31 TE
    You got it, Jerry!
    Gotta get my hands on a caliper today and get down to the boat and do some measuring to be sure that I've got the tolerences between prop and stern bearing all while still squeezing in the shaft anode. Thanks!
  10. Pitou
    Pitou Senior Member
    Dec 11, 2012
    238
    52
    Real Estate Broker
    Cape Ann
    '06 Albin 31 TE
    Jerry .. got my hands on a micrometer yesterday and things are a go. I'm probably looking at coming your way on Thurs or Fri this week. Coordinating with a surveyor buddy in W. Durham to rendezvous with him too. I'll send you a text on Tuesday so that we can figure out when to sync up.
    Thanks - Kevin
  11. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    No prob, talk at you latah!
  12. Pitou
    Pitou Senior Member
    Dec 11, 2012
    238
    52
    Real Estate Broker
    Cape Ann
    '06 Albin 31 TE
    Thanks Jerry .. good meeting you today and thanks for the tour of the yard. Small world with my tag along buddy JP knowing your brother.
    Looking forward to getting the Spurs tuned up with some new teflon bearings and a new anode. I'll probably send it down to Spurs for the full once over this time around. Thanks again!
  13. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    Thank you for the coffee, donuts, and beer!
  14. Pitou
    Pitou Senior Member
    Dec 11, 2012
    238
    52
    Real Estate Broker
    Cape Ann
    '06 Albin 31 TE
    Follow -up ...
    I sent one set down to Spurs for a tune up and then I mounted the holding block last Monday for the Spurs Line Cutter and launched on Saturday. Was a bit concerned with all of the new hardware that I'd have a vibration or even worse ... lose some performance. Neither has occurred and I've gained some security. .3125 - 18 thread II.jpg 2 inch Spurs II.jpg
    1st: Used a punch, small drill bit then 1/4" bit before using the 5/16 - 18 starter tap and then finished with a bottoming tap
    2nd: Had to cut off 1 thread of each holding block bolt length to fit / apply red loc-tite & lock washer
    3rd: Fit the cutter and then, per Spurs recommendation, I filled the exposed shaft length with zinc anodes so that a rope can't accumulate in the void
    Thanks again Jerry for putting these up on the forum. Very, very much appreciated!
  15. Diesel Jerry
    Oct 25, 2015
    2,998
    1,485
    Good to see them put to use. They had been paper weights for some time.
