My first boat project
Discussion in 'Downeast Projects and Boat Building' started by Jerzy54, Dec 16, 2016.
  1. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    Long Island New York
    1970 Pogo Custom
    I'm waiting for better temperature to start gluing things up. One thing Iwould like to ask, how much more grinding of the area yuou can see on prior pictures I need to do? I still don't see to much redish color and how important is that.
  2. Genius
    1,768
    680
    relish color? I've never heard that before. Some MEKP is red some is clear. If you are talking about the glass hull, it appears to be good for glassing. Just needs to be clean and all gelcoat or paint removed. I can see glass fibers in the picture.
  3. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    LOL. Relish, radish or redish. I'm glad you think like that. I will post another picture of the area of my concern, maybe you will comment on that area.
  4. kcassells
    kcassells Senior Member
    Jan 10, 2015
    254
    48
    Phila Master Plumber
    Pa
    Yes the actual hull glass...pink, red, radish,relish don't really have a name for it ya see.
    I'd say your there too just don't want to glass to elcrapo leftover stuff.
    Wet out a spot and post a pic. Some guys don't care what they glass to if it looks smooth.
    If you have loose fibers they need to go.
  5. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    ok, great.
  6. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    I think I have to give a little bit more grinding to these areas. What do you think? It looks worse on the picture, but better safe then sorry latter.
  7. kcassells
    Jan 10, 2015
    254
    48
    Pa
    if you are able to pull any fibers/glass off then yes more sanding. The problem being you are bonding to glass that is not necessarily secured to surface. JMHO.
  8. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    You are absolutly right, I need to grind more and I hate every minute of it.
    Keelboater likes this.
  9. fordy
    fordy Senior Member
    Mar 5, 2014
    143
    32
    Buy a dust shrowd for your angle grinder sanding discs. Eliminates all the when hooked to your shop vac
  10. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    Thanks, I will look at this.
  11. fordy
    fordy Senior Member
    Mar 5, 2014
    143
    32
  12. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    Looks good, did you use it?
  13. fordy
    fordy Senior Member
    Mar 5, 2014
    143
    32
    I have one like it. That one is for example. But they're a must have for grinding and sanding large areas and thickness.
  14. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    Thanks, ordered it on Amazon. I hope it will make a difference.
  15. Toolate
    Toolate Captain
    5,242
    1,398
    Building contractor
    Full face dust mask/respirator is the way to go too. Keep it off your face/head. 3M models are the best I have seen. Makes all the difference in the world. You can really take your time rather than feeling rushed to keep the dust down.
    Genius likes this.
  16. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    The only problem with full face mask is that you can't wear prescription glass under it. I have 3m half mask and motorcycle goggles. I just need to get a better no fog goggles.
  17. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
  18. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    I have another question about wrapping stringers, I understand that when we are using plywood for the stringers we need to put small spacers under the stringers to prevent hard spots between hull and the stringers. On the top of it when wrapping with fiberglass we are adding thickness to the whole thing. What I am asking is, if my stringers have to be 9" high should I deduct spacers and the thickness of the layup.:(
  19. kcassells
    Jan 10, 2015
    254
    48
    Pa
    No boat or hull or mold is "square"/level. Take your parts into consideration and get to be as close to where you need to be.
    You can always sand down to level then finish with glass or PB. You can also add heights to level with scab wood. They call them cleats.
    They are applied to the sides of stringers and bulkheads.
    Jerzy54 likes this.
  20. Thenthen
    Thenthen Member
    Mar 22, 2017
    13
    22'Wasque wow keep on working looks someone is busy here:cool::D
    Jerzy54 likes this.
