My first boat project
Discussion in 'Downeast Projects and Boat Building' started by Jerzy54, Dec 16, 2016.
  1. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    Long Island New York
    1970 Pogo Custom
    I did some grinding today with dust shroud and it was amazing. I didn't have to wear goggles over my glasses, I could see everything i am doing. It was 99% less dust.
    The only thing it is much harder and slower to perform grinding and also when you get to curved surface it is almpst impossible to grind without digging in. It is still worth it to have it. I have Harbor Freight cheap grinder it is onle 4.5 amps and it is not enough. Just order Dewalt 4 1/2 11 amps geinder and another dust shrout for my 7" grinder.
    I have still a lot of grinding to do to get to good bounding surface. I will post pictures in the coming days with progress.
  2. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    I almost forgot to ask if anybody could recomend and good grinding wheels for this job. I have some 24 grid and 40 grid to rough things out, but these are for steel.
    Any suggestions?
  3. Genius
    1,915
    769
    i use the festool sander with 40 grit velcro disc. It eats fiberglass for breakfast!
    If you do a lot of fiberglass work it's worth the money.
    Jerzy54 likes this.
  4. david
    david Member
    Sep 29, 2011
    17
    6
    Zec grinding pads on amazon
  5. kcassells
    kcassells Senior Member
    Jan 10, 2015
    305
    55
    Phila Master Plumber
    Pa
    With glass grinding I pretty much found that for me the tool/grinder was a "disposable" unit. I keep buying a cheap ryobi 5" wheel that will also take a 7" disc. I definitely only buy the ones that are trigger activated without a trigger lock.
    One day prior I was in the boat and one of my idiot friends left the trigger lock on. I plugged in the unit, had a metal cutting disc on it, it skipped over into my ankle, hence 20 stitches. Ouch!!!
  6. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    DONE GRINDING!!!!!! :):):):):):)
    It was a torture, she looks almost like new born baby. Now I have to figure out how to get that dust from every nook and cranny.
    Also I want to clean my boat shelter before the glassing all things back in. I just need 60 deg. weather to come.
  7. kcassells
    Jan 10, 2015
    305
    55
    Pa
    Hose it out. Let it dry then some acetone and let it dry. Also acetone helps to evaporate small amts of water hidding in thoise nooks and crannies.
    Cover up with that carpet plastic/construction stuff {sticky stuff}so your not having to clean those areas every day you walk or whatever.
    I hear ya on the weather. I'm in Pa. so we got pretty much the same crap.
    No pics no work says I. :(
  8. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    Pictures are coming, good advice. I will get in the boat shortly with air hose and vacuum cleaner and try to blow and vac as much as I can from the areas I don't want to make wet.
    After that I will follow your advice. I can wait for the fun part to start. I have an access to the industrial 6x10 router and I am planning to cut the stringers, bulkheads and in later time plywood to rebuild cabin interior.
  9. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    The proof is here.Lol. 20180330_091318.jpg 20180330_091347.jpg 20180330_091351.jpg 20180330_091410.jpg
  10. kcassells
    Jan 10, 2015
    305
    55
    Pa
    Wow you kicked some fraking ass there J!! Now if I look at your pics looks like the sweet pink I was talking about earlier.
    Hey just had a brain fart. You might want to add support{hull sides} to the trailer bunkers to support the hull since it's striped out.
    You can also run a strap across the hull to prevent distortion.
  11. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    do you think I need to do that even with the top on?
  12. kcassells
    Jan 10, 2015
    305
    55
    Pa
    I kept mine on the trailer too. I did notice some flex from the gunnels. Everything else stayed in line.
    Prob not a big deal since the top is still on.
  13. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    Spend whole day cleaning boat and the tent. Looks realy good. No dust coming from nowere when blowing compress air.
    It should be good enough. Before tabing I will clean everything with acetone and then with clean wet towel.
    I will take a coup;e days off to enjoy easter after that I hope to have warm temperture to glue transom and middle stringer to attach the keel.
    Happy Easter to all.
    Keelboater likes this.
  14. Keelboater
    Keelboater Captain
    4,406
    2,269
    Looks great! Any more grinding on that hull and you'll see daylight! :D Happy Easter to you as well.
    Jerzy54 likes this.
  15. kcassells
    Jan 10, 2015
    305
    55
    Pa
    Happy Easter also!
    Gonna try and get some boat time in as the weather permits!!
    Ok so here's the plan for tomorrow;
    -Split baby lobster tails, drawn butter
    -Spiral Ham
    -Spinach and cheese stuffed raviolis in a alfredo sauce with chopped spinach and basil pesto
    -large shrimp fried tempura with a hot sweet chili sauce and/or modified soy sauce
    -Chicken picante, lemon butter sauce
    -Beer
    Kinda doing this so I can remember what the heck I'm cooking.
    Cheers to all and Happy Easter if you celebrate the day. If not just swing by anyway for the eats.[​IMG]
  16. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    Oh boy, that is impresive list of the tasks. All look delicious and the last thing on the list is my favorite. Happy Easter.
  17. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    I am still waiting for the 60 deg. temperatures to arrive to start fiberglassing. In the meantime I am preparing and cutting stringers. As I mentioned I have an accsess to the
    CNC router and this morning I did cut first batch of stringers. After gluing them together I need to fit the hight to the floor level and cut the pitch of the hull's bottom.Here are some
    photos.
    20180428_060009.jpg 20180428_061255.jpg 20180428_062122.jpg 20180428_070320.jpg 20180428_071900.jpg 20180428_092125.jpg
    El Mar likes this.
  18. Genius
    1,915
    769
    60 degree temp? I glass all year long. What grade plywood is that?
  19. Blitzen
    Blitzen Captain
    3,310
    1,750
    Ex Merchant Marine
    I would love to have one of those CNC machines.
  20. Jerzy54
    Jerzy54 Member
    Aug 24, 2016
    88
    22
    Manager
    1970 Pogo Custom
    it is 3/4 marine ply
