NEW 12" SWIVEL ROD HOLDERS
Discussion in 'Boat Parts / Fishing Gear/ Electronics / Materials' started by ROD HOLDER GUY, Dec 29, 2017.
  1. ROD HOLDER GUY
    ROD HOLDER GUY Member
    Dec 29, 2017
    10
    6
    NEW 12" TUNA Swivel rod holder 4 bolt hole style 90 degree, top plate is 316 stainless steel the rest of the rod holder is 304 and 18-8 hardware, the liner is custom extruded vinyl and is UV protected not like the LD Marine liner that rot and pull out. My rod holders have the loop at the bottom of the rod holder not on the backing plate. My swivels use 2 1.750 nylon washers and 1/2-20 adjustment nylon friction nut. All hardware and backing plates are included. I'm the manufacture of these rod holders. I'm set-up to take PAYPAL Price is $100 + shipping. Buy 10 rod holders CASH get 1 FREE
    Please email me at rodholderguy@yahoo.com
  2. WMhunts
    WMhunts Member
    Feb 27, 2017
    30
    35
    Have you made any 15deg.?
    I'll be getting six soon would like 2 to be 15 degree
  3. BunkerMan
    BunkerMan Senior Member
    Jan 8, 2013
    307
    61
    The high seas
    Where are you located for a cash deal ?
  4. Tunatown
    Tunatown Senior Member
    Jan 25, 2016
    409
    199
    Lineman
    Plymouth Ma
    36 H&H CAT 3126B 420hp
    Yup typical.....
    Fishco and El Mar like this.
  5. ROD HOLDER GUY
    Dec 29, 2017
    10
    6
    I'm in Lawrence Ma
  6. Tunatown
    Jan 25, 2016
    409
    199
    Lineman
    Plymouth Ma
    How deep are your 15 degree swivel
  7. BunkerMan
    Jan 8, 2013
    307
    61
    The high seas
    Thanks cause I noticed you advertised buy 10 cash and get one free.
  8. ROD HOLDER GUY
    Dec 29, 2017
    10
    6
    I'm making 9" and 12" I also can make special lengths if you need
  9. ROD HOLDER GUY
    Dec 29, 2017
    10
    6
    Yes I am
  10. Tunatown
    Jan 25, 2016
    409
    199
    Lineman
    Plymouth Ma
    Ok thanks for the info I’m going to be installing 2 15 degree
  11. fullhouse
    fullhouse Member
    Nov 17, 2012
    55
    I bought 4 of these . Very happy with them .
  12. TAftw
    TAftw Senior Member
    May 31, 2015
    139
    45
    RI, Cape and Islands
    How do they compare to others that typically get sold on here? LD marine, Skurge, etc? Might buy 4 of them......
  13. SMF Marine
    SMF Marine Member
    May 15, 2016
    8
    CT
    You can give us a call at SMF Marine! Our stainless steel rod holders come in 0, 15 and 30 degree swivel or fixed. They are made with durable, polished Type 316 stainless steel face plate for corrosion resistance and Type 304 stainless steel tube that comes with a weather resistant plastic insert tube. Made in the USA.
    Downrigga and El Mar like this.
  14. SMF Marine
    SMF Marine Member
    May 15, 2016
    8
    CT
    Our stainless steel rod holders come in 0, 15 and 30 degree swivel or fixed. They are made with durable, polished Type 316 stainless steel face plate for corrosion resistance and Type 304 stainless steel tube that comes with a weather resistant plastic insert tube - give us a call!
  15. ROD HOLDER GUY
    Dec 29, 2017
    10
    6
    Hi Guys I used to machine parts for LD until he went of business, these rod holders I'm offering for $100 is the same LD made except my top plate is 316L stainless and the rest is 304L and 18-8 hardware the liner is custom extruded 80 durometer vinyl with UV protection and is press-in not glued like LD, I'm at least $60 cheaper than anybody else, I machine ,weld. polish everything in house that's why I can offer swivel rod holders at this price also soon I'll have 15 degree in 9" and 12" in stock also working on bulkhead swivel rod holders, 12" and 9" 90 degree and 9" and 12" 15 degree and bulkhead swivel rod holder are all $100ea and all will be in stock for February I'll have a website up shortly !!
    Thanks Joe
  16. TAftw
    TAftw Senior Member
    May 31, 2015
    139
    45
    Cool, come summertime I’ll be looking to buy some. Sounds like you’ve got a nice operation going good luck
  17. fullhouse
    fullhouse Member
    Nov 17, 2012
    55
    There the same as the LD better liners . There the best deal out there imo.
  18. leaky
    leaky Captain
    Sep 9, 2014
    1,789
    544
    What did LD use for the plate, tube, and hardware? Your post makes it sound like you are using a different grade of metal - makes me wonder whether you increased the quality some and made the top plate with 316L versus 304L, or if you decreased the quality some and went with 304L/18-8 versus sticking with 316L all around.
    I guess I should probably add - if you did go to 304 on the tube when previously it was 316 I get why you would do it and why it might not make a difference, just wondering what you changed. I tried to source 316 tube like that for holders at one point and the cost was outrageous versus 304, while the 316 plate was not adding much cost.
    These are good, glad to see someone picking up where they left off. Editing my post again - the bulkhead holders you are building - same as the LD ones with the separate standoffs too? If so that is outstanding - you should sell a lot of them, nobody has built a copy of those since LD went out and they were the best ones on the market.
    Jon
  19. ROD HOLDER GUY
    Dec 29, 2017
    10
    6
    LD Marine used only 304L stainless I know this because I machined a lot of top plates for LD Marine, I'm using 316L (low carbon) for my top plates, like you said the plate price isn't much different than 304l, 316 tubing is crazy vs 304 tubing and his liners where ultra high molecularly plastic witch sucks in the sunlight as you know
    Joe
    leaky likes this.
  20. Blitzen
    Blitzen Captain
    3,107
    1,553
    Ex Merchant Marine
    36 Flowers and a 1991 Boston Whaler Outrage 19
    So it sounds like CJ marine holders were 316L and then went to 304 as LD was making them? All mine are CJ Marine and never had a spec of tarnish on them. I believe the tubes were always 304 as mine do spot up over the course of the season.
