New Lady Maureen
Discussion in 'Downeast Projects and Boat Building' started by LadyMaureen, Dec 1, 2015.
  1. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    South Shore Long Island
    Wesmac
    Pics didn't upload trying again.
    tailhook and SYo like this.
  2. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    Some updated pics now with all the headliner "panels" installed. Next step trim it all out with teak battens (removable battens)
      File size:
      97.9 KB
      657
      File size:
      110.4 KB
      663
      File size:
      86.2 KB
      665
      File size:
      88.4 KB
      665
  3. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    Galley lights added.
    The Gaff and Keelboater like this.
  4. Genius
    1,558
    602
    what type of rigid foam did you use for the overhead panels. also, how did you adhere the fabric to the foam. Looks good and thanks.
    Eastporter likes this.
  5. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    The vinyl comes adhered to the foam already. I bought from DB Engineering in Mansfield TX. It's 1" thick but they also have 1/2". DB also sells the spray glue. Camie makes it. It's simply a nigh heat resistant spray version of contact cement.
    Brainey and Genius like this.
  6. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    Got the new transducer mounted and painted. Launched today. Got lots left to do but she runs. Gonna keep working in the water and maybe fish locally. 2 1/2 years so far. I miss fishing.
  7. tunaorlater
    tunaorlater Captain
    3,931
    1,993
    LIPA lineman
    What ducer did you go with?
  8. c1steve
    c1steve Senior Member
    Jan 30, 2017
    189
    26
    I am super impressed on how much you have done to a high standard. Most people take much longer or quality slips greatly.
    On the ducer fairing, could you cut more of the fairing off, so it does not stick down so far?
  9. seasar33
    seasar33 Member
    Apr 25, 2012
    31
    24
    It’s the 3D transducer for the Furuno TZT. It’s basically a 50/200/165 kHz with temp and motion sensor. Not sure how good it is but going to give it a try. There’s also a 1k-50khz built in to the keel. Maybe swap them later but use a flush mount 1k-50-200. Trying this for now.
    winterking likes this.
  10. seasar33
    seasar33 Member
    Apr 25, 2012
    31
    24
    I’m sure there was a little more room but at that location it was about a 25 degree cut. Did not want to cut into the recess for the ducer. Also fighting the keel shadow, lower might help with side scan capability of the 3D. Ideally swap location later with the built-in that’s in the keel.
  11. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    Have not made much progress on the renovation in last few weeks. Have been using the boat a little to fish local and shark tourny's. Here are a few pics my buddies on Kerri Lee took at Woodcleft shark tourney.
    Now I plan on getting back to renovation work.
    david, hntrss, Beyond Tom's and 6 others like this.
  12. Old Mud
    Old Mud Captain
    3,242
    2,443
    Retired Fisherman
    Looks Super !!
  13. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    Finally started milling the teak and trimming out ceiling panels. All the teak trim and panels are removeable in case I need to run a wire, change a headliner panel or bolt through the roof.
    restless, Genius and Eastporter like this.
  14. Genius
    1,558
    602
    looks very nice. How did you attach the strips to the overhead that the teak battens screw into? I saw in earlier photos it appeared to be a lot of shimming and looked more complicated than I would imagine. thx
  15. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    The strips that attach to the actual roof were screwed and glued (5200). The shims were mostly about keeping the foam panels underneath the bolts on bottom side of roof from mast stays. Also the shims needed varied to create a uniform crowned finish with panels installed.
    Genius likes this.
  16. Genius
    1,558
    602
    wow, attention to detail. Did you use a string line to establish a plane?
  17. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    637
    755
    Wesmac
    Yes. A string at times, other times a long straight edge (alum angle iron). And a phrase my carpenter buddies refer to as " eye-fucking ".
    restless and The Gaff like this.
