Non Tox Antifreeze
Discussion in 'Downeast Engine Room' started by restless, Dec 6, 2017.
  1. restless
    restless Captain
    Jan 22, 2014
    1,481
    909
    Just picked up five gallons of non tox for the boats water systems. It says on the label that it's not intended for use in engines. I'm assuming that it's ok to use on the raw water side of the system and the disclaimer is intended for engine coolant side. I've used it before but never noticed the warning about not using in motors. Are there two types of the -50 F pink stuff?
  2. F/V First Team
    F/V First Team Captain
    5,856
    2,157
    Not for use in engines as ENGINE COOLANT
    Not a valid replacement for the green stuff that tastes like kool-aid
    And not the government kind either
    restless likes this.
  3. Genius
    888
    286
    Moorings
    Yes two different types. One has alcohol in it.
    Theory is that the alcohol attacks and damages o rings and other plastic parts. I try to use the Propylene Glycol type.
  4. BlueMack
    BlueMack Senior Member
    Oct 14, 2014
    320
    89
    New Hampshire
    Bruno & Stillman 35
    One on left ok for engine winterazation. One on right I do my Head, fresh water, wash down pump. One on right I get at Ace hardware on sale in October for 1.50 a gallon. One on left never goes on sale, get case discount at NEMI. You can see fine print on the reddish color one has alcohol.
  5. ArchHibb
    ArchHibb Senior Member
    Aug 31, 2013
    449
    309
    Architect
    Marblehead
    Five Islands 35 w/Cat 3116
    I assume you meant the one on the left never goes on sale...
  6. ArchHibb
    Aug 31, 2013
    449
    309
    Architect
    Marblehead
    So if the theory has any reality, why would one want to use it on FW systems and the like, all of which have o-rings and plastic parts? Is there evidence the theory is nothing more than just that?
  7. El Mar
    El Mar Captain
    6,019
    1,976
    Had a friend that put Vodka in his fresh water system.
    Fun times in the spring....
  8. Blitzen
    Blitzen Captain
    2,481
    1,166
    Ex Merchant Marine
    Flowers 36 and a 1991 Boston Whaler Outrage 19
    That is why my water tastes so good.:)
  9. ArchHibb
    Aug 31, 2013
    449
    309
    Architect
    Marblehead
    Just add mixer... :D
  10. Duke
    Duke Senior Member
    Dec 9, 2011
    336
    127
    Rye, NH
    Dyer 29
    I use compressed air to blow out the freshwater system. I don't like putting that stuff in the freshwater system plus it's a bitch to get rid of the taste in the spring. It says non-toxic but it kills the grass....
    Duke,
    Hallelujah Newman 36 likes this.
  11. BlueMack
    Oct 14, 2014
    320
    89
    New Hampshire
    Bruno & Stillman 35
    Thanks, edited,
    Also don't dump non tox in your tank!!! You'll never get it all out, I have a spot in the line I break, drain tank put pump end of hose in gallon jug and pump through system, it flushes out completely in spring.
  12. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    2,098
    1,027
    We use the Camco brand on everything here at the yard. Never have any issues with rubber breakdown. Never pour straight into you F/W tank and don't forget to bypass and drain the water heater. I winterized boats from Sept. to Dec. if you need any help call or email. Also don't forget to test the freeze point of the engine antifreeze.
