Penn International 130H
Discussion in 'Tuna Talk' started by F/V KRISTA MARIE, Feb 10, 2018.
  1. F/V KRISTA MARIE
    F/V KRISTA MARIE Member
    Feb 4, 2015
    61
    Stamford
    General Marine 26
    It this reel worth buying used and servicing? I plan on using it for Bluefin and I noticed it’s a single speed. Also does anyone know if the drag washers can be upgraded from the factory asbestos ones?
  2. BlueMack
    BlueMack Senior Member
    Oct 14, 2014
    344
    98
    New Hampshire
    Bruno & Stillman 35
    It all depends on the purchase price.
    You can send it to Cals speed shop and have it souped up. I can't remember the ratio on that reel, but I rarely shift into low gear. If I do it's only in the final minutes of a fight or if I feel it's tail wrapped. A god resource for this reel is the Alan Tani web site
  3. F/V KRISTA MARIE
    Feb 4, 2015
    61
    Stamford
    General Marine 26
    Cool thank you. Asking is $200 and it’s in great shape.
  4. El Mar
    El Mar Captain
    6,119
    2,016
    Can't go wrong for $200
  5. BlueMack
    Oct 14, 2014
    344
    98
    New Hampshire
    Bruno & Stillman 35
    I would get that
  6. F/V KRISTA MARIE
    Feb 4, 2015
    61
    Stamford
    General Marine 26
    Grabbed both of them. Does anyone know what the factory max drag are on these older 130’s?
  7. leaky
    leaky Captain
    Sep 9, 2014
    1,723
    502
    I have a 130H and it will put out 40+ lbs of drag anyway - I never tested it for "max" because we set ours at ~35 or so on strike so that's all I cared about.
    If you look on scotts bait & tackle website for the 130H they list all the cross referenced part #'s - including updated drag washers to fit the original design:
    PENN 130H Parts List
    However also my believe is you can take the drags, gears, most of the guts, spools, etc.. from a 130ST (which is the 1 piece frame) and put them into a 130S, 130H, or 130L (which are the multi piece frame models, the S is a 2 speed built on the same frame as your H). In some instances you may need to replace extra parts to make it work but I believe you can take most of the ST parts and they fit right into the S/H/L frame.
    Jon
    LACI GALE 31jc likes this.
  8. Ms.Aimee
    Ms.Aimee Senior Member
    Aug 27, 2015
    307
    186
    Maine
    Agreed i have a 1030H and ive never felt the need for full drag. I set mine around 32-35lb of drag. Not sure where your out of but i use lukes reel repair out of kennebunk. People from all around travel to bring theyre 130s to him. Takes awhile but he does a great job.
  9. F/V KRISTA MARIE
    Feb 4, 2015
    61
    Stamford
    General Marine 26
    I actually used Leaky’s tutorial to break them down. They have the original asbestos drag washers, so I ordered the newer Dura Drags to replace them.
  10. Tuna Hotline
    Tuna Hotline Senior Member
    Mar 19, 2012
    179
    77
    Mortgage Loan Originator
    I run 42 @ strike on mine. Never an issue. They can put out some serious drag.
  11. tuna_fan
    tuna_fan Senior Member
    Mar 22, 2012
    460
    125
    Gloucester, MA
    caught lots of fish on the 130h - great robust reels. single speed is fine. i never shift into low using the shimano's... good call updating the drags. personally, i would put the shimano grip on there too..
    you stole them for $200.
    xbskt likes this.
  12. F/V KRISTA MARIE
    Feb 4, 2015
    61
    Stamford
    General Marine 26
  13. leaky
    leaky Captain
    Sep 9, 2014
    1,723
    502
    It looks like a good deal and generally I'd trust Seaguar just like I would any major brand, do you know if it's spectra or dacron? Dacron is cheaper, still would be a good deal though. BTW I think I pay about $100 for 600 yards of jerry brown hollow and it gets cheaper in bulk - that is still cheaper than I pay per yard but just saying it's not outragously expensive either.
    Jon
  14. Downrigga
    Downrigga Captain
    Mar 25, 2016
    764
    342
    Harwichport MA
    36' NB
    Full drag is 95 lbs. You will never need it. Make sure you heat the reel up before setting your strike #. Mine is set at 45 lbs. Back off the strike a bit if you are using live/dead bait and stationary. Move back up to strike after the initial hook up. My advice is to never put dacron on a 130.
  15. F/V KRISTA MARIE
    Feb 4, 2015
    61
    Stamford
    General Marine 26
    Why no Dacron? Spool rot?
  16. F/V KRISTA MARIE
    Feb 4, 2015
    61
    Stamford
    General Marine 26
    While we’re at it.
    Joshbel02 likes this.
  17. Downrigga
    Downrigga Captain
    Mar 25, 2016
    764
    342
    Harwichport MA
    36' NB
    yes, plus hollow core you can splice so it makes it very handy for tuna fishing and you can also load up a reel because of the dia.
    JB TACKLE in Conn has tons of used international reels if you are looking to add to the collection. When it comes to your terminal gear stick to proven products because giants will find the weak link in your armor every time.
