Prop Tune & Engine RPM
Discussion in 'Downeast Engine Room' started by JimRP31, Jun 26, 2018.
  1. JimRP31
    JimRP31 Captain
    Oct 21, 2011
    252
    Sales
    tiverton RI
    Willis Beal/RP 31
    When I first bought my boat it had a lot of vibration at all RPM's. I had my Prop tuned this winter. I have a Yanmar 6LYA-STE. I filled the tanks up and too the family for a spin. It was a little choppy but no real waves. I think the prop tuner got it right. But I am open to opinions.
    RPM's Speed in Knots
    2000 10
    2500 13.9-14
    2700 15.2
    2800 16
    2900 16.8
    3000 17.6
    3100 18.3
    3200 19 WOT
  2. Gurryman
    Gurryman Captain
    Sep 6, 2012
    939
    491
    New Bedford MA
    Nauset 28, CuttyHunk 28 Molds
    That motor is rated at 3300 RPM, you need to see 3400 at WOT :(
    Diesel Jerry likes this.
  3. duckhunter
    duckhunter Senior Member
    Mar 21, 2017
    204
    159
    1984 Nauset 35 flybridge
    I'm with Gurryman. Better to be underpropped by 100rpm - especially at the beginning of the season, with a clean bottom and fresh prop - than running right on the ragged edge. Turning 100rpm under rated is not a recipe for longevity.
    Did it cure the vibrations? If so, that's a win, but I'd see if the prop guy would take out a little pitch for you.
  4. fortier256
    fortier256 Captain
    Feb 10, 2013
    505
    161
    Narragansett Bay
    Fortier 26
    Agreed on minimum 3400 WOT loaded. That number comes from Yanmar. Be sure to use a photo tachometer at least verify your boats tachometer is correct.
  5. powderpro
    powderpro Captain
    Dec 3, 2011
    2,728
    1,692
    The Ocean
    O'Neil
    Maybe you already have, but verify your throttle position is 100% at full throttle. Would hate to see you repitch the prop if the prop isn't the problem.
    fortier256 likes this.
  6. BillD
    BillD Captain
    5,651
    1,375
    Business owner
    I'd take 2.5" of pitch out of the prop "after" you've verified "full throttle advance" 100% and that the WOT you measured is via "photo tach".
    For long term engine life.....Better to be "over propped" than "under propped". It's all about "engine load" and keeping EGTs below max spec.
    Just my 2 cents.
  7. JimRP31
    JimRP31 Captain
    Oct 21, 2011
    252
    Sales
    tiverton RI
    Willis Beal/RP 31
    All good points.
    Duckhunter it did cure the vibration. I did not want to try WOT until I cured the vibration. BillD, Fortier256, Gurryman & Powederpro all good point. I agree with your assessments that I am overpropped at the moment but I did not give the prop guy any RPM guidance (due to vibrations) we agreed to a best guess. Gurryman, I will confirm I am at the full throttle position and get a photo tach to confirm RPM's. I am going try a few more runs over the summer and pull the prop when I haul the boat in the fall. I will say the engine sounds the best and runs smoothest at 2900. I am still learning.
  8. steveinak
    steveinak Captain
    4,315
    1,709
    H&H / Pen Bay
    Don't ya mean better to be under propped ?? for less engine load ??
    Genius likes this.
  9. traditions
    traditions Captain
    Oct 9, 2011
    1,109
    280
    38 Holland
    I think you got that Bass Akwards Bill
  10. powderpro
    powderpro Captain
    Dec 3, 2011
    2,728
    1,692
    The Ocean
    O'Neil
    After 5,500+ posts, he was bound to get something backwards.:D
    Toolate likes this.
  11. BillD
    BillD Captain
    5,651
    1,375
    Business owner
    ya backwards....sorry.....
    The 6BTA 370 in the 25 T Jason is propped to reach 3250 rpms.
    The 370 is rated 355bhp @3,000 rpms.
    The mechanical governor, under load, will not let the engine spin up to 3250 so you'd
    never see true WOT on the tach. I've photo tached @ 3180 ish. WOT
    How could I help verify my 370 was really under propped to 3250 WOT if I could never "see it" on a tach?
    Any takers on the question ? :cool:
  12. 05bill
    05bill Captain
    Oct 10, 2011
    556
    85
    cape cod
    rp, willis beal
    I have same boat , same motor, RP put 22 x 22 prop on. Yanmar tech at splash said all was fine. I reached 3300 rpms. I had prop repitched to 22 x 20 .I now get 3450 wot, a little under propped but that is fine with me, piece of mind.
    I do not run that engine past 80 % of wot rpms !!! Jim 2900 ?
  13. fortier256
    fortier256 Captain
    Feb 10, 2013
    505
    161
    Narragansett Bay
    Fortier 26
    That’s right where you want to be. You would probably be able to run at the Yanmar posted continues rating (3200?) if you wanted to without any ill effects. It’s the load / EGT that is the killer not RPM.
    Genius likes this.
  14. Genius
    1,798
    696
    What is High Idle RPM spec for the engine?
  15. 05bill
    05bill Captain
    Oct 10, 2011
    556
    85
    cape cod
    rp, willis beal
    Fortier 26, I hear you but I am a conservative guy,3200 I would be a nervous wreck.
    Genius the spec says 3300 , but we all know it should be higher, to 3400-3500.
    Fortier do you know the pyrometer range , for this engine prior to turbo ? I know but just checking .
  16. 05bill
    05bill Captain
    Oct 10, 2011
    556
    85
    cape cod
    rp, willis beal
    Oh Genius that number is 3700 rpm. Sorry I didn't see idle rpm.
  17. Genius
    1,798
    696
    05Bill, I was responding to BillD's post on the cummins.
    I'd have no problem running your Yanmar at 3200, sounds really good at that speed. Like fortier256 says....
  18. fortier256
    fortier256 Captain
    Feb 10, 2013
    505
    161
    Narragansett Bay
    Fortier 26
    I do not have the info for your motor. However my 4LH manual calls for less than 1200f at WOT.......Before the turbo.
    eyecatcher likes this.
  19. Beamie
    Beamie Senior Member
    Jun 3, 2012
    224
    49
    Well, a good accurate charge air boost pressure gauge will tell allot about load when compared to test bed results.
  20. JimRP31
    JimRP31 Captain
    Oct 21, 2011
    252
    Sales
    tiverton RI
    Willis Beal/RP 31
    Bill, just to compare I have a 22" diameter LH that the previous owner reduced to 21. My Pitch is 20.8. I am over-propped at this point but I don't want to take the haul the boat until the fall. I can comfortably run at 2900-3000 for this summer. I still need to confirm I am getting full throttle and get a photo tach. I will say once I get it dialed in I will run it 3200 without a worry.
    Fortier, forgive my ignorance but what is EGT?
