1. chasintail
    chasintail Senior Member
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    I have a 24 x21 prop on a 13/4 shaft if I went to a 24x24 what effect should that have ...... THANKS
  2. mudhake
    mudhake Captain
    Oct 6, 2011
    700
    360
    at least a 300rpm loss, depending where you are now on the correct rpm scale.
  3. ulf75
    ulf75 Senior Member
    Jun 3, 2012
    102
    27
    Jamaica Bay, NY
    37' Repco (project)
    I have a 24x25 or 26 4 blade nibral, Left hand, 1"3/4 shaft NIB
    Bought for a project, wound up going w different motor
    If your interested
    -Scott
  4. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    iveco 270 hp 35 Bruno extended keel looking for more speed ........... so going to a24x 24 will bring 2900 rpm wide open down to 2600 it will make me slower ?
  5. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    what should I go to for more speed ?
  6. Genius
    1,798
    696
    You should be thinking about engine health, more than speed. If you are at the upper end of of your engine HP at WOT, getting a prop with longer legs will not do anything for you but cost you money in engine repairs/life.
    Best to run your numbers through a prop calculator or find someone who has a similar set up to compare (even then, its not the same). If you play around with props you may figure out where you are with engine loading.
    Tautog18 likes this.
  7. plowin
    plowin Captain
    Dec 14, 2011
    1,167
    768
    Firefighter/Half Assed Fisherman
    Newbury
    33' flowers
    What should be wide open throttle rpms be?
  8. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    wide open in neutral is 2900 ....2950
  9. Genius
    1,798
    696
    I have no idea about isuzu engines, not familiar with them, need a model number. I believe it was meant as isuzu not iveco.
  10. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    iveco 270 hp I get 20 knots wide open clean bottom run at about 2200 15, 16 knots with pulpit and crows nest on
  11. Genius
    1,798
    696
    my bad. What's your WOT RPM, in gear.
  12. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    2900 ..........2950
  13. Brooksie
    Brooksie Captain
    Mar 25, 2013
    1,187
    368
    If you are running at the engine makers specified RPM at WOT with existing prop, and if existing prop has been checked & tuned; going for more pitch or diameter will just overload your engine. Going from 4 to 3 blades often results in slightly more speed IF the 3 blade has proper blade area to prevent cavitation. If not, you will loose speed. Occasionally a different brand or style propeller will produce slightly more speed.
    Maybe shed some weight first as Bruno's are not the best weight carriers also have your tach checked to be sure what you are saying is actually true.
    Finally, an unmodified 35 can really only handle a 22" prop as a 24 does not have enough clearance either above or below. I have always run a 22" on mine and picked up a full knot by dropping my skeg bar and shaft years ago, giving it proper room to work, fairing the deadwood didn't hurt either but I can't remember how much...
  14. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    I modified it extended keel by about 6 or7 " shaft tube, dropped shaft,, longer rutter ,fairing some that's how I got to The 24 ....I could have a little capitation now looking at prop but not sure
  15. Genius
    1,798
    696
    so....like I said, I don't know the engine (or model #). But, if you are 2900-2950 in neutral (governor) and also hitting governor set point in gear and the specs for the engine support that, you may have some room to increase pitch. If you have the gear ratio, water line length and displacement I can run a prop calculator?
  16. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    thank you , I don't know the displacement though , I had it figured when I put that motor in 4 yrs ago , and that's how I ended up with that 24 x21 ......
  17. hardcore1
    hardcore1 Captain
    Apr 27, 2012
    539
    321
    moriches ny
    The most important factors are what is the engine supposed to reach at wot? and what is your gear ratio? Then what are you achieving with the existing prop which appears to be 2950rpm. Given all of that info you can be strafed in the right direction
  18. Numasahake
    Numasahake Captain
    Apr 26, 2014
    589
    366
    Retired, dammit
    Penobscot, Maine
    Dodge Stationwagon
    Why don't you install a pyrometer in the exhaust manifold. Then you can monitor EGT's. As long as EGT's don't go too high at wot, you'll be fine with the bigger prop. Heck, I run a pyrometer in my 17 hp Lombardic Diesel powered Arctic Cat 700 ATV. I'm sure I'm the only one in the universe to have done that...
    eyecatcher likes this.
  19. Wharf Rat
    Wharf Rat Captain
    Apr 24, 2012
    652
    277
    Radar Tech
    City Island, NY
    OPB
    Hey Guys,
    Really sorry I missed this thread, I have it set up so I get an email for the electronics posts, but not this one apparently. That said, it looks like you guys have already taken it to another level, and I'll be totally honest that this sht is WAY over my head, and my boss aka 'Greg Diesel' on the forum (although I don't think he knows how to post or has the time) is still in Islamorada fishing as we get the whole month of Feb. off for VaCa. We're back in the office on Monday, he's most likely going to have a pile of work to do but I'll fill him in and see if he as anything worth contributing. I will say I have actually learned a bit from this thread in particular, but I know that under/over propping is beyond any kind of exact science, but it's good to know once again the DEBF crew has it covered. Talk to you guys soon, I'm actually itching to get back to work, although by Monday afternoon I will regret even thinking that.
  20. chasintail
    Jan 5, 2013
    254
    30
    haverhill ma
    bruno35'
    IF I GO FROM A 24 X 21 TO A 24 1/2 X 26 WHAT EFFECT WILL IT HAVE ? MORE SPEED OR MORE TORQUE ? THANK YOU
