Repower Engine Moving Question
Discussion in 'Downeast Engine Room' started by AvidAngler, May 11, 2018.
  1. AvidAngler
    AvidAngler Member
    Feb 25, 2017
    Hi, I will be possibly doing a repower in the near future and am looking for a bit more information on the physical moving and installing of engines with the least amount of cutting of the cabin. It is a twin engine boat with no large direct access at the moment to the engine room. Already accepting I need to cut out the door to the cabin to crane out the engines, is there a way to cut a single hatch dead center of the cabin and shift the motors off their mounts and over to the center of the boat for lifting? By doing this, save me from having to redo the cabin setup and only cut one hatch hole? Please let me know if more info is needed.
    Thanks!
  2. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    2,762
    1,360
    Post pictures.
  3. AvidAngler
    AvidAngler Member
    Feb 25, 2017
    PM’d
  4. captcod
    captcod Member
    Feb 1, 2013
    52
    11
    where on cape cod are you?
  5. Toolate
    Toolate Captain
    5,031
    1,311
    Building contractor
    You can take the old ones apart piece by piece but the new ones have to go in complete :)
    I would be thinking of a homemade system of beams. Maybe find a way to bolt some angle irons across the front/rear of the motors and slide some cross pieces under them so they could slide. No easy way that I know. You have room enough to go up over the stringer/inboard engine bed and not have the top of the engine hit the deck?
    Sounds fun...
  6. chortle
    chortle Captain
    Mar 7, 2012
    735
    294
    retired
    Annapolis, MD
    There are all sorts of options :)
    Genius likes this.
  7. F/V First Team
    F/V First Team Captain
    5,983
    2,265
    I did a pair out of an Egg Harbor with it sitting outside, anything is possible.
  8. Genius
    1,364
    508
  9. xbskt
    xbskt Captain
    1,170
    870
    electrician
    28 Crowley Beal
    You beat me to it. Depends on your fiberglass skills.
  10. AvidAngler
    AvidAngler Member
    Feb 25, 2017
    Thank you to all the responses! I decided to not take on the boat or the project for the time being and will continue the search for a different boat!
