Rod Holder Brace
Discussion in 'Tuna Talk' started by parmentj, Sep 10, 2018.
  1. parmentj
    parmentj Member
    Feb 13, 2012
    19
  2. jig boat
    jig boat Member
    Jun 6, 2013
    31
    6
  3. cb34
    cb34 Captain
    Oct 31, 2011
    954
    204
    cb34,
  4. Old Mud
    Old Mud Captain
    3,606
    2,770
    Retired Fisherman
    Parme, are you looking to through hull bolt them ?
  5. fat2nawilly
    fat2nawilly Senior Member
    Oct 27, 2011
    232
    117
    Cape fisherman supply in Chatham has one on the shelf,saw it there few days ago, not sure on brand but it's what you're looking for.
  6. duxbait
    duxbait Captain
    Sep 28, 2011
    701
    185
    Fisherman
    Duxbury MA
    If you are gonna bolt through the hull you could take a piece of 1" starboard, hole saw it for the rod holder to go through then drill holes to through bolt it to the hull. I've seen that done a few times and plenty sturdy.
    I know of 3 broken rod holders this year alone.
  7. Squider42
    Squider42 Senior Member
    Aug 23, 2014
    113
    16
    Just curious, did the holder itself break or did it just break up the fiberglass it was bolted to?
  8. hotreels73
    hotreels73 Member
    Dec 12, 2012
    84
    91
    I’ve broken 2 this year and 1 a few years back. They break where the weld meets the bottom of the plate. LD rod holders
  9. Tunatown
    Tunatown Senior Member
    Jan 25, 2016
    449
    216
    Lineman
    Plymouth Ma
    36 H&H CAT 3126B 420hp
    Definitely think the holders you fight out of should have backing plates and torque plates well at least a torque bracket at the bottom of the rod holder there’s a lot off force on the rod holders I have seen and heard horror stories lengthXforce=torque so 50 pounds at the tip could be 400 pounds at the rod holder I’m sure there’s plenty of us breaking the will on the fish or lifting them up at the end putting more then that at times
  10. Tuna Pursuit
    Tuna Pursuit Captain
    Feb 26, 2012
    1,085
    224
    Self Employeed
    Beverly ma
    Thunnus
    Mine have a counterbore in the top flange so the tube goes into the flange half way. Bottom brace is always a good idea.
    www.randrfisheries.com
    restless likes this.
  11. duxbait
    duxbait Captain
    Sep 28, 2011
    701
    185
    Fisherman
    Duxbury MA
    I have 5 R&R on my boat and haven't had an issue yet. I even use them as mounts for my mackerel gear.
    Tuna Pursuit likes this.
  12. Old Mud
    Old Mud Captain
    3,606
    2,770
    Retired Fisherman
    This is what i use, made from 2" x 4" x 3/8" 5456 Aluminum. Through bolted the hull. :eek: I even use the one next to my hauler for my portable davit for hauling my anchor. I swear you could roll the boat with those things. Yes i have had a couple of Bad experiences. :).
    toomuchtuna, duxbait and El Mar like this.
  13. duxbait
    duxbait Captain
    Sep 28, 2011
    701
    185
    Fisherman
    Duxbury MA
    Thats how they should all be. You make those yourself?
  14. Old Mud
    Old Mud Captain
    3,606
    2,770
    Retired Fisherman
    Yep , the holders and braces, pretty easy.
  15. Tuna Pursuit
    Feb 26, 2012
    1,085
    224
    Self Employeed
    Beverly ma
    Thunnus
    This is exactly what mine look like. They are a generitc size so you might have to make a starboard spacer or some other material.
    Old Mud likes this.
  16. Old Mud
    Old Mud Captain
    3,606
    2,770
    Retired Fisherman
    Or, you could use Oak spacers. :) Actually that is what i used because it was easier to cut down Wood . The spacers will vary as to where you have your holders mounted if their not all in line. (Fair to the hull shape) not the wash rail.
    I know what your going to say, "Starboard will last longer". I put those in 18 years ago. They still look good (no rot). Well now, i'm just a few months short of 80. So, i won't be worrying about them falling apart anytime soon. :D
    Tuna Pursuit and winterking like this.
