Rudder port packing to dripless
Discussion in 'Downeast Boat General Discussion' started by Frontier, Nov 11, 2017.
  1. Frontier
    Frontier Member
    Nov 23, 2016
    43
    34
    Has anyone switched from standard flax packing type port 20171111_124211.jpg
    to a dripless style spud nut
    Is it just a bolt on? Any potential issues?
    My rudder shaft has some slight wear from the flax packing, but below where i assume this type seal would ride feels true. It doesnt look like these get greased either, so no maintenance?
  2. Blitzen
    Blitzen Captain
    2,438
    1,146
    Ex Merchant Marine
    Flowers 36 and a 1991 Boston Whaler Outrage 19
    If it is truly dripless and there is no water feed I would worry about crevice corrosion. At least with packing you can adjust it so there is just a touch of water exchange.
    Frontier likes this.
  3. traditions
    traditions Captain
    Oct 9, 2011
    955
    169
    38 Holland
    I hope you never have to take that box out, looks like a bitch
  4. Frontier
    Frontier Member
    Nov 23, 2016
    43
    34
    Yeah, its on good, previous owner musta had a barrel of 5200 laying around, its on everything
  5. zues
    zues Member
    Dec 14, 2014
    8
    Pipefitter/Shore Engineer
    New Bedford
    topaz 24
    3 seasons with this unit.
    so far no issues
    purchased from Buck Algonquin
    standard thread for exact replacement for standard packing nut.
    zues,
  6. Frontier
    Frontier Member
    Nov 23, 2016
    43
    34
    Thanks, im going to order it, and repack the original as backup
  7. c1steve
    c1steve Member
    Jan 30, 2017
    88
    11
    What works really well for packing is standard packing plus a stainless grease fitting, if there is room. The area is pumped full of marine grease. The grease both stops water dripping, and protects the metal.
    To remove the 52oo bedded materials, there is a product called Debond. Supposedly works great when removing 5200 applied products.
  8. Frontier
    Frontier Member
    Nov 23, 2016
    43
    34
    Yes, ive seen those. I could probably just drill and tap a zirk for my current spud. Good idea
  9. southshore30
    southshore30 Senior Member
    Feb 22, 2012
    180
    46
    firefighter/charterboat captain
    Cape Cod,MA
    Calvin Beal/Southshore 30
    Torch also works really good too. That’s what I do when I have to remove mine to pull the shaft or on other pieces of hardware installed with 5200. Use aluminum tape around the edge on the fiberglass so not to burn in and apply heat, it will de bond the 5200 while warm
    Tunatown likes this.
  10. Tunatown
    Tunatown Senior Member
    Jan 25, 2016
    172
    67
    Plymouth Ma
    36 H&H
    Second on the heat I’ve used a torch or a good heat gun it will pop right off
