Running on low oil
Discussion in 'Downeast Engine Room' started by pennh2o, Jan 12, 2018.
  1. pennh2o
    pennh2o Senior Member
    Dec 18, 2013
    125
    10
    Brooklyn,NY
    I was doing some maintenance on the boat yesterday and checked my oil level. The oil was well below the minimum mark. Only the tip of the dipstick had oil on it. I don't remember when I last checked the oil level however the last oil change was on 9/7/2017. I put 200 hours on the engine since that time. Engine performed normal the whole time. I do have a oil pressure gauge that never went off. Engine is a Volvo 63P-A with about 5200 hrs.
    Should I be concerned?
  2. djmarchand
    djmarchand Senior Member
    Jul 24, 2012
    415
    105
    Oriental, NC
    Mainship Pilot 34
    I wouldn't be concerned about running low on oil; you probably still had 2-3 gallons left in the crank case. But sudden high oil consumption would be a concern to investigate.
  3. WoundUpMarine
    WoundUpMarine Captain
    2,700
    1,061
    Boothbay, Maine
    34 Libby, 14 Holland
    Agreed, I would be more concerned about where the oil went rather than running it low on oil. If it was still on the dipstick, even just on the tip, your fine. Is the boat at a weird angle anything as to why the oil level would be off? Any oil in the bilge from a possible leak?
  4. pennh2o
    Dec 18, 2013
    125
    10
    Brooklyn,NY
    Boat is in the water so no weird angle. No oil seen in the bilge. The engine did not burn oil in between previous oil changes.
  5. WoundUpMarine
    2,700
    1,061
    Boothbay, Maine
    That's a tough one, how much oil did it take to bring it back up to full? If it is burning oil there are an awful lot of place it could be going. Heck an oil scraper ring could have gotten stuck and burned the oil and freed up again. Best you can do is fill it up and monitor it more closely, see if it happens again and if so get a rate of how much oil you're burning.
  6. Keelboater
    Keelboater Captain
    4,066
    1,964
    Clinton Harbor & North Cove
    You might want to take a look at the engine coolant. Anything milky is never a good sign.
  7. RockBottomFish
    RockBottomFish Senior Member
    Nov 5, 2014
    151
    43
    Montauk
    BHM
    My 3208 burns about a quart for 10 hours running time, was told this is normal. Put a Hal gallon in every other trip.
  8. MASTERENEGADE
    MASTERENEGADE Captain
    Sep 15, 2012
    1,994
    604
    NORTHPORT
    Had a DE, now 24' Privateer
    I haven't met a motor that does NOT burn some oil. Some motors such as Detroits (an example) use more oil then others. I work on quite a few different boats and various different engines.
    I would do what WoundupMarine stated to do: monitor your oil more closely and see how much oil per trip you are losing. And def check your coolant to make sure that is normal.
    I religiously check the oil and other fluid levels every trip on any vessel I run..I do not ever want to have to be the one to make the call to a owner, that I just smoked his engine.
  9. Kodiakan
    Kodiakan Senior Member
    Aug 26, 2013
    458
    97
    As was said, if it showed a bit on the dipstick you'll most likely be ok. Some engines start to use more oil as it gets dirty (towards the oil change). Could be it used the oil at the end of your hours. All good advice above.
  10. riskybusiness
    riskybusiness Senior Member
    Mar 5, 2012
    399
    181
    maine
    35 five islands
    Pull the stick wipe it off, put it back in and give a 10count or else it will give you that false low reading. My tamd63p does that but prob check it more than once every 200 hours
  11. CEShawn
    CEShawn Captain
    Sep 21, 2011
    2,871
    857
    RP35
    Like they all said, keep a better eye on it. In that too, see if your condition has changed alot. When I ran my boat at 8 knots to the canyons and back never burned any oil really, just a little bit. Now when I do my cod trips, at 14.5KT, blazing speed in my regard, after two trips, I know I like to add a qt before the 3rd... So be aware of what your doing to it as well, if that has changed.
    As we have seen in the posts here, make it easy to inspect coolant/oil dipstick etc, if you make it easier, you will do it more and to save on these engines, its a costly mistake not too.
  12. pennh2o
    Dec 18, 2013
    125
    10
    Brooklyn,NY
    Understood, will be monitoring weekly.
  13. BSEA
    BSEA Member
    Aug 29, 2017
    8
    BSEA,
  14. BSEA
    BSEA Member
    Aug 29, 2017
    8
    How many hours do you have on your TAMD 63P?
    What is your typical cruise speed and RPM in your 5 Islands? Good looking hull.
    I have one in a NB 36' with approx. 1,200 hours, all good so far.
    Never had an dipstick reading issue, all oil analysis so far have been normal
    BSEA,
  15. fortier256
    fortier256 Senior Member
    Feb 10, 2013
    498
    155
    Narragansett Bay
    Fortier 26
    Just a thought......
    I am not familiar with Volvo’s however if the dipstick tube is down in the oil it will take a few minutes for the oil (especially with cold engine) to find its way up into the tube. Pull the stick and wait for 5 minutes or so then re-stick it and see if the oil is further up on the stick. This is a common “quirk” with some engines and I have seen them over filled with oil because of this.
    tailhook and Genius like this.
