Sealing your mast from water
Discussion in 'Downeast Boat General Discussion' started by pennh2o, Nov 16, 2017.
  1. pennh2o
    pennh2o Member
    Dec 18, 2013
    94
    8
    Brooklyn,NY
    I want to seal the hole where wires enter in my mast. Every time it rains or there is a lot of spray, water drips into the wheelhouse where the clump of wires exit.
    What is the best way to go about this?
  2. Blitzen
    Blitzen Captain
    2,557
    1,230
    Ex Merchant Marine
    Flowers 36 and a 1991 Boston Whaler Outrage 19
    If you have a picture it may help show us how the water may be getting in and what could be used.
  3. SeaKarma
    SeaKarma Senior Member
    Apr 26, 2014
    217
    252
    Merrimack River, MA
    I took a hole saw to some plywood which gave me a round plug, then I wrapped it in shipping tape and waxed it. I used this to mold a small fiberglass cylinder, which I put into the canopy so that the entry hole stood a little proud of the canopy surface.
    This cylinder fits into the hole on the radar mast. I haven't tried this out yet as my boat is yet to see water, but it seemed to make sense to me.
  4. Genius
    993
    329
    Moorings
    A pad and a small coaming piece like shown above works good for the mounting. At the mast/radar mount I use a grommet for wire protection with a glob of clear silicone. Having an exit point at the bottom of the mast is also important.
  5. Old Mud
    Old Mud Captain
    2,659
    1,942
    Retired Fisherman
    I did the same as SeaKarma except i used a piece of PVC and stood it up 3 " through and a 1/4" hole in the aft of my mast. Never had a problem.
    NightBite likes this.
  6. Hammer Slammer
    Hammer Slammer Senior Member
    Sep 7, 2011
    274
    89
    Builder
    Plymouth, ma
    28' BHM
    I used a thru hull from the bottom up and just cut the extra off
    morgan1727, Old Mud and Tunatown like this.
  7. Toolate
    Toolate Captain
    4,897
    1,242
    Building contractor
    If you can loop the wires in such a way as to make a drip loop with a low point that is not over the hole in your roof it might help. Simple as pulling back some slack and arranging it so the water drips where you want it to as it runs down the wires.
    SeaKarma likes this.
  8. pennh2o
    pennh2o Member
    Dec 18, 2013
    94
    8
    Brooklyn,NY
    Took me a forever but here is the mast
    Dr Dude likes this.
  9. JimRP31
    JimRP31 Captain
    Oct 21, 2011
    883
    176
    Sales
    tiverton RI
    Willis Beal/RP 31
  10. Blitzen
    Blitzen Captain
    2,557
    1,230
    Ex Merchant Marine
    Quick and easy would be to pull some slack in all those cables so the water would not run right down the cables and into the mast. Then cover the the hole with a clam shell cover.
    Pitou, Toolate and Genius like this.
  11. pennh2o
    pennh2o Member
    Dec 18, 2013
    94
    8
    Brooklyn,NY
    whats a clam shell cover?
  12. Blitzen
    Blitzen Captain
    2,557
    1,230
    Ex Merchant Marine
    Find one like this that fits over the hole and the wires.
  13. Blitzen
    Blitzen Captain
    2,557
    1,230
    Ex Merchant Marine
  14. Toolate
    Toolate Captain
    4,897
    1,242
    Building contractor
    You definitely need to pull some slack back on those wires and make a drip loop too. A few have said it but here is a pic of what we mean just in case. Rain or spray will run down the wires from the radar and then have to drip off because the wires will then run uphill into the clamshell/hole.
  15. pennh2o
    pennh2o Member
    Dec 18, 2013
    94
    8
    Brooklyn,NY
    Thanks guys, very helpful.
    Will make a drip loop and add a clamshell plate with silicon. Hoping should do the trick.
