Shaky Yanmars
Discussion in 'Downeast Engine Room' started by El Mar, Jan 9, 2019.
  1. El Mar
    El Mar Captain
    6,494
    2,264
  2. JPO
    JPO Member
    Mar 22, 2013
    54
    15
    Wood Products Broker
    Yarmouth, Maine
    AJ 28
    Not something my 6LY does.
    No shake here!
    JPO,
  3. Genius
    1,914
    769
    properly sized motor mounts and having them balanced for load would be my guess.
    Gurryman likes this.
  4. archsea bunker
    archsea bunker Member
    Mar 25, 2012
    98
    11
    Are the stringers shaking also ? or is it just the video.
    Genius likes this.
  5. Keelboater
    Keelboater Captain
    4,402
    2,267
    Looks like a structural nightmare to me.
    BOSBoatMan and Shor2832 like this.
  6. eyecatcher
    eyecatcher Senior Member
    Sep 30, 2012
    124
    34
    The more wiggle the more negotiating room. Sad to say it doesn't look good. From here engines sound okay so unless they were missfiring due to a bad injector or cylinder down or alignment , bent shaft prop they shouldnt shake like that. Long term I'd suspect structural issues with the stringers from loose engine beds or mounts, and possible engine transmission issues and leaks from vibrations etc.. It looks like barry mounts in the front. They are one of the best out there. But nothing lasts forever maybe a poor intsallation where something wasnt torqued down or maybe something broke. Needs a good surveyer to check for tabbing and delamination issues at the stringer base and the bulkheads, also inspect all the running gear. It did appear that the outboard battery box was moving too.
  7. djmarchand
    djmarchand Senior Member
    Jul 24, 2012
    457
    128
    Retird engineer
    Atlas Pompano 23 outboard
    Was that video taken in gear or out? Makes a big difference in possible causes. Even better post it both ways.
    Diesel Jerry likes this.
  8. El Mar
    El Mar Captain
    6,494
    2,264
    Looks that way.
    Apparently the video was taken during seatrial running at cruise if you read the original post on THT.
  9. goin4broke
    goin4broke Captain
    Aug 28, 2015
    987
    350
    Electrician
    Mystic,CT
    What is up with those engine beds? Looks like nothing I would mount an engine to. Agree the motors sound good and it’s hard to tell if it’s underway. My guess would be it is. Any ripple in the water would cause the shaking. Disaster waiting to happen.
    tailhook likes this.
  10. Toolate
    Toolate Captain
    5,328
    1,437
    Building contractor
    Floppy bottom sporty? (Flexi flyer?)
    Wow
  11. El Mar
    El Mar Captain
    6,494
    2,264
    Its actually in a 36 Hatteras, not a flexi flyer.
    We had a flexi flyer for years, never saw it flex.
    Toolate likes this.
  12. 05bill
    05bill Captain
    Oct 10, 2011
    580
    92
    cape cod
    rp, willis beal
    good engine , and it sounds good., steam at cruise is o k as well. do not understand the shacking. it would concern me.
  13. Lion's Paw
    Lion's Paw Senior Member
    Mar 31, 2012
    147
    36
    Frisco, NC
    42 Duffy
    I had a 36 Hatteras and the series one and two hulls are very overbuilt. Its not the stringer system moving around there. No way they fail as they are really beefy and mostly solid glass. I had a set of cat 3126 420 and they didnt shake like that ever. I believe the mounts are moving but why is the question. I would inspect the shafts, props and cutlass and intermediate bearings and of course those mounts. Cant keep anything close to aligned with that much movement and it must make the whole boat quiver.
  14. Keelboater
    Keelboater Captain
    4,402
    2,267
    There appears to be an aluminum angle that is mounted on top of the stringer with risers welded to it. I suspect it's the interface between the stringer and the angle that poses the problem. A poor mounting method enables "twisting" of the angle, which is magnified by the height of the risers. The higher you go, the greater the movement becomes noticeable. It might actually be an easy fix if the stringers are solid..............but we all know how that goes.
  15. southshore30
    southshore30 Senior Member
    Feb 22, 2012
    254
    92
    firefighter/charterboat captain
    Cape Cod,MA
    Calvin Beal/Southshore 30
    Looks to be a little rough out, I’m even seeing the batteries shaking at one point. Can’t be good for exhaust connections or the shaft loading for alignment. Glad it’s not a issue I’ve been tasked to diagnose and mitigate
