suzuki df 115 2012 need help
Discussion in 'Downeast Engine Room' started by capecodnativ, Jul 9, 2018.
  1. capecodnativ
    capecodnativ New Member
    Dec 15, 2016
    The motor is starting and coming up to speed perfect. If i throttle down to quickly though the motor will cut out.Happens in both ford and reverse. Have checked the spark plugs. New fuel filter and fuel water separator. New low pressure fuel pump last week. Don't believe it to be the gas only use premium in it an and going through a whole tank a week. Any ideas to try are greatly appreciated.
    -Thank You
  2. Plastered
    Plastered Member
    Feb 13, 2017
    13
    Plasterer
    Weymouth
    31 jc
    Check your battery cables clean and tight I had same motor with similar problem was just loose connection
