Transducer Mount for Trailerable Inboard
Discussion in 'Marine Electrical / Electronics' started by Blackfindan, Jun 26, 2018.
  1. Blackfindan
    Blackfindan Senior Member
    Oct 12, 2013
    218
    68
    1977 24' Blackfin Combi (sold)
    We have a new to family 22 ft shamrock inboard (1999) center console toted around on roller trailer.
    It’s not a downeast, but at least I don’t have to fish this year from the inflatable.
    Boat does not have a depthsounder.
    Any recommendations on how to mount a transducer? Can’t really do a through hull because the trailer rollers touch the entire hull as it rolls on/off the trailer.
    I know you can’t do a transom mount because of the prop wash.
    Any solutions for this?
  2. Captinlon
    Captinlon Member
    Mar 28, 2016
    52
    6
    Coast of Maine
    32 H & H
    don't know much about how their hulls are constructed, could you do a in hull (shoot threw) I know they are not the best, but I honestly don't know. I know if you have a solid hull (no core) I would consider it
  3. Blackfindan
    Oct 12, 2013
    218
    68
    Thank you. Had not thought of that.
    I think it is a solid glass hull. I will check into that. I am not the owner, I will just pay the fuel bill.
    Anyone have a recommendation on a particular model transducer for this?
  4. steveinak
    steveinak Captain
    4,233
    1,630
    H&H / Pen Bay
    Ya better call our in house electronics nerd/guru "Wharf Rat" chris will get ya rigged up right. I have a airmar shoot thru hull 1kw transducer in my rig and it worked great right down to 1000 ft. at least thats as deep as i tried setting my shrimp pots. By the way i also have a regular through hull transducer and i trailer the boat, the transducer fits right between the bunks no problem.
  5. Old Mud
    Old Mud Captain
    3,242
    2,443
    Retired Fisherman
    Cap. you CAN use a transom mount with no problems. I use one and can read mud bottom in 100 Fathoms at 20 Kts. That's with a 600 watt sounder. I can post a pic. if you want.
  6. Wharf Rat
    Wharf Rat Captain
    Apr 24, 2012
    628
    253
    Radar Tech
    City Island, NY
    OPB
    If you don't want to use a transom mount or in hull, you can use any of the Airmar tilted element transducers, they were designed with an internally tilted element so they would sit flush to the hull, no fairing block and no issues when trailering the boat. They make them in 12 degree and 12 degree versions, and based on the dead rise of the potential transducer location, you'd go with the angle closest to that deadrise. The B60 transducer was the first 50/200 Khz solution and is still kicking; they've come out with some larger CHIRP versions like the B75M & B175 but those would be overkill on that boat.
    http://www.airmar.com/uploads/Brochures/b60.pdf
    steveinak likes this.
  7. Blackfindan
    Oct 12, 2013
    218
    68
    Thanks for the replies
    Would the trailer roller damage the airmar transducer on contact?
