Tuna 2017 running report
Discussion in 'Tuna Talk' started by JasonD, May 26, 2017.
  1. Tuna Hooker
    Tuna Hooker Member
    Apr 22, 2012
    78
    22
    Rochester, NH
    Not much you can really do except reel them up and clean them regularly.
  2. leaky
    leaky Captain
    Sep 9, 2014
    1,659
    479
    Yah - same guys came in with 2 the other day, you can't win them all I guess. I remember one trip when we lost 3 fish 3 different ways and had like 5 hours into fighting fish and were beat with nothing to show for it, was getting really frustrating. Usually though I figure if you aren't loosing them you aren't hooking them either and that's the hardest part. On that trip we did eventually get one that was a probably a grander before it's last shit, of all things was like 9 at night we were trying to cook steaks and it ate a little tinker mack set back on a trash bag :).
    Jon
    HUNTHARD likes this.
  3. leaky
    leaky Captain
    Sep 9, 2014
    1,659
    479
    Ditto - check the lines a lot, may require a check every 20 minutes even. Quickest way is to use a rag to push all the slime down to the crimp by the leader then work it off by sorta pushing it to the crimp and tearing it off - similarly from the hook up slide the line through the rag to push it up to the swivel then work the crud out - do not get lazy at the end of the day about it either as it will harden and really adhere to your gear.
    Jon
    CornerOffice likes this.
  4. coddock
    coddock Senior Member
    Sep 3, 2011
    256
    29
    Nope, we were giant fishing. Fish ended up being 105"
  5. ForTUNAte Son
    ForTUNAte Son Member
    Aug 24, 2016
    17
    Is anyone doing anything new or innovative to color crimps? I use a Sharpie to blackout my crimps but the color wears off throughout the day. This isn't a big deal, as I can dry and re-color, but it got me thinking about using heat shrink tubing or something more durable. Do you think the scent from the Sharpie is noticeable, or am I over thinking this entire process in general?
    getthenet likes this.
  6. Ripcat
    Ripcat Senior Member
    Sep 7, 2012
    280
    60
    Hampton Falls, NH
    I used to color mine with a sharpie but then found that electrical tape worked better. I use a specific type, stretchy and thin, and it works well.
  7. baitnh
    baitnh Member
    Mar 18, 2016
    11
    try black oxidizing them you can get kits on line
  8. leaky
    leaky Captain
    Sep 9, 2014
    1,659
    479
    I can't imagine the sharpie hurts anything but ditto on what he said too - they seem to wear off, I like quality electrical tape - 3M super 33 is a very thin sticky stretchy tape that says on there better.
    Ripcat likes this.
  9. Cdux
    Cdux Member
    Mar 20, 2014
    90
    42
    So. Me
    Black shrink tubing for crimps
    As for slime, fish 3 in the water instead of 4, & near constantly cycle them. That way I alway have a clean one on hand to deploy.
    Cdux,
    JasonD likes this.
  10. baitnh
    baitnh Member
    Mar 18, 2016
    11
    even better I like that idea
  11. Ripcat
    Sep 7, 2012
    280
    60
    Hampton Falls, NH
    When you guys use shrink tube...doesn't that get a little sketchy putting heat that close to your leader or mono? I use the heat shrink butt connectors on everything i do electrically on my boat and i don't think i'd want to apply that much heat to my fishing line but maybe i'm off base.
  12. Cdux
    Cdux Member
    Mar 20, 2014
    90
    42
    So. Me
    Like most things with fishing & life; its all in the technique. Pre shrink the mono side & shield with your fingernails doing the rest.
    Cdux,
  13. Downrigga
    Downrigga Captain
    Mar 25, 2016
    741
    328
    Harwichport MA
    36' NB
    I use a black paint stick. Touch anything with it and it dries almost instantly, with no wear off. Hooks, crimps, whateva. Its just an slightly oversized laundry marker only with fast dry paint. I don't like the idea of shrink tube for giants if you are trying to be as stealth as possible. Some days they will eat a tin can. On days when they are shy, being as steath as possible might pan out still. I would blame the shrink tube. I don't ever use the full size crimp for that same reason. Fish that have been hooked before are smarter too.
  14. leaky
    leaky Captain
    Sep 9, 2014
    1,659
    479
    I like the paint idea may try that, actually have at least one black paint stick kicking around I use for something else..
    As far as the heat & shrink tube, mono and flouro is fairly robust stuff, for years I used superglue on my finger splices because that's just how you did it then somebody said "won't that eat the mono?".. Got me a little worried but I figure if it was gonna eat the mono it would've already, never had a problem with one of those with the glue, so I still use the glue - maybe some other guy finds a glue that eats the mono, maybe some other guy melts the mono trying to set the tube, I dunno. The tape is gonna be smaller diameter next to the paint though, but the tape sometimes comes off.
    Jon
  15. Downrigga
    Downrigga Captain
    Mar 25, 2016
    741
    328
    Harwichport MA
    36' NB
  16. Downrigga
    Downrigga Captain
    Mar 25, 2016
    741
    328
    Harwichport MA
    36' NB
    blow on the paint thin as can be.
  17. leaky
    leaky Captain
    Sep 9, 2014
    1,659
    479
    What I meant by that is thinner than the shrink tube, thicker than the paint.
  18. Ms.Aimee
    Ms.Aimee Senior Member
    Aug 27, 2015
    296
    182
    Maine
    Whenever i fish with my boss he puts about 6 wraps of electrical tape on the hook crimp so you have this big glob right next to your bait presentation.. it drives me nuts. Im going to try the paint stick next time im out
  19. Cdux
    Cdux Member
    Mar 20, 2014
    90
    42
    So. Me
    Ground fishing charter Saturday, they showed up early so didn't get to slip the 130s onboard, that was a mistake. Right at slack the sounder lights up, & had this going on for 10 minutes:
    Figure they were picking off our shorts on the way back down. Took a lot of restraint not to pull the shark rig off the 50 and send her down. They did grab 2 cod jigs, which was short lived and now got a pair of 114s in sick bay awaiting new drag washers.
    Cdux,
  20. SemperFishBoston
    SemperFishBoston Senior Member
    Jan 3, 2015
    235
    111
    Fireman
    Indian Ridge, Ma
    AJ26 Duffy
    Went out Saturday around 4 pm. Planned to put in a 24 hour tour on the NWC but it was loaded with dogfish. Tried to fish through them but they depleted my bait rather quickly throughout the night. a couple hours after sunrise switched gears and went on the pogy slow troll well south. No dice this time. Radio chatter indicated I picked the wrong corner. Again lol.
