Xducer splice
Discussion in 'Marine Electrical / Electronics' started by SHORT STEP, Sep 10, 2018.
  1. SHORT STEP
    SHORT STEP Senior Member
    Apr 9, 2012
    196
    18
    retired
    w/ma
    Tripp / midland
    is it possible to splice a raymarine plug to a furuno xducer , 7 pin radar type R/M >> 10 pin furuno , all I need is depth
    Bob
  2. Keelboater
    Keelboater Captain
    4,136
    2,027
    Clinton Harbor & North Cove
    Airmar might make an adapter for this. Give them a call.............
    Airmar
  3. Old Mud
    Old Mud Captain
    3,424
    2,598
    Retired Fisherman
    Yes i think they do have an adapter for that combination. They didn't have one for me though. I went with a P-66 with an 8 pin Standard Horizon plug. Hacked it off and rewired it to a 10 pin Northstar. Works great.
  4. SHORT STEP
    Apr 9, 2012
    196
    18
    retired
    w/ma
    Tripp / midland
    Thanks , I have 3 cut tducers cables that I picked up over time . I have a raymarine mfd with DSM 300 that I want to use with a furuno or garmin
    Tduce , I don't know on the ray mfd both shields go to drain, furuno has 1 shield to # 9 ant the outer shield to # 3 , and the garmin the shield to # 5 .
    If I use either witch go tu shield on the mfd ?
    #1 is ray marine # 2 is furuno and 3 is garmin
  5. Wharf Rat
    Wharf Rat Captain
    Apr 24, 2012
    646
    265
    Radar Tech
    City Island, NY
    OPB
    Unfortunately you CANNOT connect any of those transducers to a Raymarine unit; Raymarine uses a 'Sense' wire in their transducers and are the only manufacturer who does so. That prevents any compatibility with other branded Airmar transducers; you must use a Raymarine transducer to work with the DSM. Sorry, it's shitty, been an issue for years.
  6. SHORT STEP
    Apr 9, 2012
    196
    18
    retired
    w/ma
    Tripp / midland
    Thanks Warf rat
    I had a idea that would be a issue as ray marine are more $ than the others . I have a R/M shoot thru hull I will use .
    Bob
  7. SHORT STEP
    Apr 9, 2012
    196
    18
    retired
    w/ma
    Tripp / midland
    Read the sense wire is for 1 kw . For a 600 w it's bl>bl , bk>bk , bare>bare and connect Brn & green together on the RM side of the splice ,depth only
