19’ Skiff
Discussion in 'Skiffs and Small Work Boats' started by ptm, Oct 24, 2018.
  1. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Hi,
    I picked up this boat yesterday.
    Does anyone recognize what it is? Who might have made it?
    ptm,
    jdickau484 likes this.
  2. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Before I put the deck down should I drill drain holes through the floor frames to allow drainage?
    ptm,
  3. Eastporter
    Eastporter Captain
    2,712
    651
    Great boat to fix up, Are you going to use epoxy or poly? Fiberglass the sole? Are the stringers in good shape? Now's the time
    to replace if needed. I would glass the stringers down and then epoxy the floor (sole) on both sides at the very least. Mat/cloth with proper tabbing. Are you putting hatches to the bilge? You can drill limber holes in the stringers for water- or just glass the whole sole without any hatches and keep a dry bilge.
  4. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Hi Thanks,
    The hull and stringers had all been sealed and are in very good condition. The stringers are fastened to the hull with what looks like thick epoxy tooled around all the edges. I don’t see any rot. I think I’ll seal everything again with epoxy before I put the floor/sole down. Great idea to do hatches. I’ll put one in each bay, no limber holes. Then try to seal the whole sole to key it dry.
    ptm,
  5. El Mar
    El Mar Captain
    6,736
    2,454
    I would definetly cut limber holes in the frames, seal them up with epoxy just for good measure.
    Maybe put a brass tube in but that might be overkill.
  6. GLA
    GLA Senior Member
    Sep 11, 2012
    323
    123
    it looks exactly like a life boat that the life guards use here at the jersey shore,
    usually two guys rowing
    GLA,
  7. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Thanks,
    Would a piece of copper water pipe be ok to use in the holes?
    ptm,
  8. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    I agree, it looks a little like a lifeboat. Not the same transom or bottom
    ptm,
  9. Toolate
    Toolate Captain
    5,541
    1,577
    Building contractor
    Trick learned from @fvfirstteam. Take a paint roller tube and drill a hole large enough for it to slide through your frame. Then cut it to maybe 1/4” more than the thickness of the wood its going through and dip it in thickened epoxy and push it into place. Then fillet the squeeze out and you are done.
    Paint roller with plastic inner tube not paper obv...
  10. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Ok. Thanks
    ptm,
  11. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    My next question.
    The transom measures about 22” from the top to bottom. Should I cut it down to 20” for a 20” outboard?
    ptm,
  12. Eastporter
    Eastporter Captain
    2,712
    651
    Yes- you are correct. 20" for 20" leg. You can always cut more off after a sea trial if needed.
  13. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Thanks,
    ptm,
    Eastporter likes this.
  14. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Next question,
    When I put down the sole and seal it all up, do the air spaces under the sole count as flotation? Is that enough flotation?
    ptm,
  15. Eastporter
    Eastporter Captain
    2,712
    651
    It is pretty cheap to add rigid home insulation from Lowes or HD. That's what I did. Are you making a boat to last or just get in the water? I would glass all the new plywood and the transom then paint it all with marine enamel or epoxy paint.
  16. Eastporter
    Eastporter Captain
    2,712
    651
    Hatches or no hatches? If it is truly a sealed bilge then it would act as flotation but still better to go with rigid insulation and then add a hatch. It is good peace of mind to see the bilge or just seal it up and don't worry about a bilge pump etc.
    Toolate likes this.
  17. ben2go
    ben2go Member
    Dec 9, 2012
    64
    15
    A dory aka Jersey Skiff. There is probably more info on the Wooden Boat Forum and maybe a source for plans if you're looking for that.
  18. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Thanks, I’ll take a look.
    ptm,
    ben2go likes this.
  19. ptm
    ptm Member
    Apr 7, 2016
    15
    8
    Ivoryton, CT
    Got it.
    I’m in no rush to get it in the water.
    Is Ben Moore latex floor and patio paint ok for inside? Or should I use something else?
    ptm,
  20. Eastporter
    Eastporter Captain
    2,712
    651
    I've had good luck with Brightside one part paint from Interlux. I'm currently rebuilding a sailboat and using Total Boat wet edge enamel and it works okay too. I wouldn't use non-marine paint on a boat- but it is up to you.
