Andyf32
I have been reading this board for the last 2 years to get motivated to finish this project. Unfortunately I have come to the realization that I do not have the time or room to finish it.
So here it is:
1994 21' Williams Marine - built by a small builder in MD who it seems has since gone out of business.
MD22 Volvo Penta diesel, 59hp with 218 hours
Straight shaft boat, I do not know the ratio of the gear (it may be on there I didn't look)
Condition - The fore deck was soft and has been removed and partially replaced. The workmanship is not the best but you can be the judge. There is some areas on each side of the gunnels that were ground out but the new core was not properly sealed and will need replacing. The cabin top has some core issues on the edges. New cutlass bearing installed in the strut, strut needs to be bolted back on.
The cockpit seems mostly solid except for the trim strips around the engine. However I am not an expert so you would want to inspect it yourself.
I have a CT registration for the boat in my name. The trailer has never been registered so I was unable to register it when I bought it. The trailer is fit to the boat and is solid overall. The tires are not good and the brakes will need work.
Pictures tell most of the story but feel free to ask questions.
Asking $5000
Boat is currently located in Ledyard CT (Near Mohegan Sun and Foxwoods)
Message me here or at:
[email protected]
So here it is:
Asking $5000
[email protected]
