Welcome to General Marine, Inc.: Model Lines
The General Marine 22 is a classic downeast
hull design that incorporates the latest in modern
building methods. It’s fully molded, modular,
foam filled stringer system and penske
board reinforced transom offers the stiffest,
strongest method for reinforcing the hull, sole
deck and transom, and because it’s all composite
you don’t need to worry about water absorption.
The hull comes with hand laid fiberglass,
using epoxy based vinyl ester resin. The 22
boat is built to tough New England standards
and comes with a 10 year structural warranty.
The General Marine 22 was designed by the
legendary Maine lobster boat designer, Calvin
Beal. With her 9’ beam and semi displacement
design, this boat has unparalleled stability and
sea keeping abilities.
