I’m sure it could be bought after he’s done w itwho’s getting the 25’ plug?
Not sure was miss daisy originally an inboard? The keel is just more drag and isn’t needed in an outboard and think it would bite in a following sea.. 22 GM, 23 CB, 25 NB all have a small keelI like the 10" keel on the old Miss Daisy 22' Webco. It seems the new ones have a smaller keel. Any insight?
Thanks John. Yes the built in chine should lift it and do away with needing spray rails same as 32 Wayne Beal .. the flat spot he cut out will give the outboard cleaner water.. he thinks the mold will take another week or so maybe more and then the hulls will come out shortly there after . Really looking forward to it.Very interesting. AtoZ and Bill, it appears there is a flat keel pad near the transom like a lot of go fast boats have. Also, the chine at the rear looks rounded then hit s the hard chine lifting/spray rail a couple inches up. I'm interested if the chine will help the hull break free of the water and ride on the pad at higher speeds. Any insight? When are your hulls supposed to be laid up. Nice flare in the bow.
Ok...thanks A...do you have a contact number for him...Give John a call. See what his schedule looks like. John’s marine.
