26 Duffy repower
SemperFishBoston
Indian Ridge, Ma
AJ26 Duffy
Big shout out to billy (the parts guy) at MerriMar in Newburyport. Great guy who works hard for us and outstanding value on top of that. Thanks again billy!
SemperFishBoston
Indian Ridge, Ma
AJ26 Duffy
Also Mr. Larry at Accutech prop in dover nh. I have a 20x18 nibral 4 blade wide surface area prop enroute. Lead time is 1 week to arrive and a few more days for him to go over it, add cup, and make sure its otherwise on point.
SemperFishBoston
Indian Ridge, Ma
AJ26 Duffy
Need to extend the stringers 10” so decided to just taking them to the bulkhead so i can add my power steering pump and wash down pump via a bracket and belt off each side to the pto. Prepping area. Glass work tomorrow.
c1steve
I recommend using epoxy resin for bonding to old polyester, where strength is important. Epoxy bonds with 6x the strength what glassing to old fiberglass.
SemperFishBoston
Indian Ridge, Ma
AJ26 Duffy
So use something like a west system six10 thickened epoxy to bond the new stringer to the old stuff before fiberglassing over?
xbskt
28 Crowley Beal
Will you be notching and lapping the old stringer and new to add contact surface area? A lot stronger than a butt joint.
xbskt
28 Crowley Beal
Ive been thinking about that. Do you mean something like a dove tail?
Same idea.
More like a step. Matching notches that you could glue (thickened epoxy) and screw before glass. A vee notch is also an option but tough in a bilge.
The idea is to create a mating surface that is a structure that is compressing on itself and resists rotational loads and stands up to axial loads.
A butt joint isn't enough in my opinion especially if it is on a stringer that will hold a motor.
Will your engine beds span across the joint?
PatriciaLynn
Cape E
Repco
I have seen the difference quoted as much less that 6x. I believe PE is around 20% less strong. Important to consider, but not make or break. The boatworks today guy did a test and I was surprised. Pulled coosa apart before the poly failed.
SemperFishBoston
Indian Ridge, Ma
AJ26 Duffy
Same idea.
Yes they will. the aluminum angle will span the joint with the backing plate
