chasintail
looking for motor for old bruno running gear also ... CHEAP thanks
The 375 hp Deere that was removed for the repower we just did is for sale up at Marine Systems in Bass Harbor Maine. I am pretty sure that it is still there with a reverse gear. Not sure how much the customer wants but it is a running take out.looking for motor for old bruno running gear also ... CHEAP thanks
thank you SirThe 375 hp Deere that was removed for the repower we just did is for sale up at Marine Systems in Bass Harbor Maine. I am pretty sure that it is still there with a reverse gear. Not sure how much the customer wants but it is a running take out.
How much SIRSent you a PM.
they sold it ! thank youThe 375 hp Deere that was removed for the repower we just did is for sale up at Marine Systems in Bass Harbor Maine. I am pretty sure that it is still there with a reverse gear. Not sure how much the customer wants but it is a running take out.
thank you that might work out !
but what do i want a 2 /1 or 11/2 to 1 with that? he might just sell motor. thanks a lot![]()
35 bruno.. 22 pulpit and 22 crows nest. i think 1 3/8 shaft , prop 21 by 20 i think 453 dd with 72 series, he said might not sell the gear with it. i talked to him . thank you just wanna put the gear with it that gets that thing moving the fastest i can. thanks
35 bruno pulpit tower ,453 dd 72 series velvet drive i believe 21 bt 20 wheel ..... cummins motor low oil pressure 20 lbs 8500 hrs $2000
Thank you sirChasintail,you will not be able to use a 2.5 to 1 gear...a 35 bruno doesnt have enough clearance to swing a big wheel...plus your shaft is to small...the seller of the motor also has a 1.75 inch shaft for sale....that would be better with the 2 to 1 gear
not sure what gear is in there now . i been looking for that gear 507What gear do you have now ? Borg Warner? 2 to 1
