Field Tester
Well, I'm finally getting started on my repower and rebuild. I've been doing a lot of research, and speaking to a lot of different people over the past year about my ideas for this and got A LOT of different answers as to how I should go about it. The new power plant will be a Cummins 6CTA. A big issue with this repower is running a big enough wheel for the hp I will have. The second issue is even if I can run a big enough wheel, will the hull provide enough water to it? There has been many discussions on this forum and others about prop size, gear ratio, shaft speed, load, etc in any boat. I have taken a lot in, and have spoken to prop shops, mechanics, other JC owners, etc, and here is what I plan on doing. I am modifing the hull to get a bigger wheel under there. I have been told by just about everone to try to get a big enough wheel to run a 2:1 gear. The biggest wheel I can get under there with what I currently did will be a 26. And that's pushing it with having enough clearance all around. I would be running a 26X30, or there abouts, and I don't think the hull will provide enough water for that much pitch. I think I'm going to go with a 1.77:1 gear and run a 25X25 (again, or there abouts). I will have a good 3-4" above the top of the prop. So here are the pictures of where I'm at. A before shot, then the afters.
