joelucci33
So Im running a steady 208 temp under load in the 3126 (300 hp model)..book call for 195...any ideas on what could be causing the 10 degree difference?
Buddy of mine had a similar problem, it turned out when he turned on the gauge lights the temp gauge would go up 10 degrees ???
Have you cleaned out the aftercooler and turbo lately ? Clean bottom? I had a pyrometer on my old boat and when it started to grow grass and slime up on the bottom the pyro would go up 10-15 degrees. The old boat had a 41 volvo in it and when the raw water pump was worn/bad impellor the temp would climb. Maybe you have some broken off impellor pieces blocking the raw water flow ??
Steve,
Brandy new Impeler...Brandy new CAT turbo...after cooler cleaned boiled etc..
I havent jumped in the water to check the strainer yet...but Im getting awesome water pressure..50 PSI under load.
I second the coolant advice.Also what coolant are you using and are you sure it is at the proper dilution if not using ELC from Cat?
