32 MC Prop
ATM
Have a 32 MC with 300 hp cat 3116 , 2800 rpm ,2/1 Twin Disc. Boat is basic lobster boat as far as weight. Prop on there is 23x20 rh bronze,1 3/4 shaft, looking for advice on a larger diameter prop. Dont run boat hard looking for best efficientcy at 12-13 knots, any prop meisters with some input? Plenty of room for bigger wheel. Engine turns up 2800 on dash tach wot ,never no loaded engine at dock (THATS SCARY!) thanks
fvthunder
I had a 32 Mitchell with a 300 John Deere @ 2450, 2:1 TwinDisc, basic boat.......that turned a 26x27.5 with a full cup
ATM
no cage ,use boat for tuna fishing , get 19.5 knts at wot and as said that is at 2800
ATM
32mc prop
Thanks for that. boat definitly needs new wheel , and that seems more in line with other 32MC's that i have seen.
You are there!
You are where you want to be. Granted even though you can take a larger diameter you will need to give up pitch. I would not change the wheel. Your efficiency currently with your 23 X 20 is .85% you are there. 85% with a keeled boat is very good. If you went with a 26 wheel your pitch would be only 17 your WOT speed at 100% would be 19.60 knots. You will never achieve 100% wheel efficiency in a DE boat.
