I’ll give a little tease………
Ripped out all of the cockpit washrails & the transom livewell.
Wasn’t happy with the shape of the livewell I made a few years ago & previous owner installed all the rod holders & wasn’t big on de-coring, nor was he big on de-coring when he fucked with the transom scuppers (transom core was wet as was a lot of the washrails, tuna door & fish hold lid) Plus rod holder layout sucked.
While visiting Bill to check out his boat build I saw a livewell tank he had on the floor & was looking to sell. Perfect shape & size though I modified & wrapped the sides & bottom with 1” Davina cell.
Cut the top off & layed up a new solid glass one with a very large lid. Livewell will be glassed/incorporated into the transom & washrails. Will be elevated off the deck to fit a tote underneath.
Washrails are going to be 1” Coosa. 5’x 12’ board made for making them in 2 sections with a small filler center of the transom.
xbskt
13 Whaler, 14 Salty Boats, 36 Northern Bay. WTF!?!
Yet again, I have garage envy...
All in Ronnie. Well worth it for a great hull.
Made some progress on my washrails & coamings.
Spent more time thinking about design how I wanted it layed out than to make them up.
1” Coosa for both washrails & coaming
A bit more glue (hull & deck) & stainless screws then they come back off & back into my garage on the lay up tables to glass bottom side and the benefit of gravity instead of glassing upside down.
Changing up the tuna door from a 1 piece to 2
Door was way too heavy 1 piece and not really gusseted up for my liking.
16 Calvin Beal
Nice work Ronnie
xbskt
Good call. Working upside down sucks.
A couple of guys I know have no washrail where their door is. Never loved it but their doors are super easy to use.
4 days worth of grinding,de-coring & clean up done (thank god !!!)
De-cored areas done with hull & deck putty I’m finally starting to put it back together.
Transom-cockpit hull sides & transom door just going to get glassed up heavier (fuck putting core material back on !)
The devinicell deck had some areas to patch where a wire chase (pvc) was eliminated and have no friggin idea why, but port side deck behind winter back, previous owner had a large aluminum Diamond plate screwed & glued down covering a big hole. Will install a new 1624 P&E hatch
Patched that big hole with 1” Coosa
Hope to have all of transom glassed up heavy by weeks end, install 4 new Lumitec underwater lights across the transom then start patching in across the stern and make a new ramp for the tuna door.
16 Calvin Beal
Ronnie are you going to recore the hull sides ? If so what are you going to use ?
Unless you've done this stuff, you can only guess at the hours involved.
Lots of hard by hand work there.
The air tool lots quite dangerous :cool:
Good to see you back at it.
Boat will be better than new !
