Tom Stewart
I would like to get a little more speed out of this vessel.
Current configuration is:
Volvo TAMD 63L - 318HP
Twin Disc 1.5:1 gear
1.5" shaft
21x18 4 blade prop
2300rpm gets me 13.5 - 14 knots loaded depending upon conditions/current, etc.
I would like to put in a reman Cummins 450C.
Questions are:
Thanks for your input.
ts
1.5" shaft
21x18 4 blade prop
Questions are:
- I can probably get a 23" diameter prop maximum....Any suggestions...I will go over to BoatDiesel, but I'd rather chat with someone who has done this conversion or something similar on this hull.
- Do you think this will get me 17-18 knots cruise?
- This vessel has a bronze tailpiece that the cutlass bearing is located and the rudder sits on so to speak. I'll have to wallow that out to be able to get a 2" shaft in it....I've got a call in to Henriques, but any comments on this from past experience would be appreciated.
- Any suggestions on gear?
ts
