That's no deal, I believe you can get a new one for around 175k or 185k. That's just a basic commercial lobster boat.
Here is what you get today, add another $50k for engine and controls and now you can start to finish the boat. You are at $200K with no extras. Just add up the items you would like to add and the cost to install and you will be well over that 200.
All the little things add up very fast.
Hull:
- White Calvin Beal 36'
- Solid Fiberglass Laminate (No Core) Polyester
- 1" Main/Lazarette Foam Core Bulkhead
- 2 Main Stringers, 2 Outboard Stringers Doubled Up in Engine Bed Area
- Stringers Thru Main Bulkhead
- 1" Foam Core Main/Lazarette Bulkhead
- Double Up Stringers in Engine Bed Area
- LIft Kit 2"
Top:
- Long Top 10'
- Overhead Fared
- Balsa 1" Overhead, Foam Core Sides
- Upgrade to 3/4' Foam Core Sides
- Solid Coamings
Misc:
- Engine Install With 2" Shaft and Coupling Aligned To Engine, Inside Cutlass, Outside Cutlass, and PYI, Engine Not Included; Not plumbed and Wired
- Install Drip Pan, Engine Bed Webbing With Limber Holes
- Install 316 S/S Rudder w/ Rudder Step and Packed Box
- Top Installed, Fastened and Glassed On
- Installed PVC Spray Rails
- Installed PVC Lifting Rails
- Installed PVC Quarter Guards
- Installed 2 Oval Bronze Zincs
- Installed 4" Copper Bonding Strap
- Installed Aluminum Fuel Tanks (Approx. 300 Gals.) Set On 1/4" Neoprene Rubber Above a Custom-Built Fiberglass Tank Bed
- Aft Engine Room Bulkhead
- 8" Wet Exhaust/Muffler Installed (Sounddown Verna LIft Muffler, S/S Exhaust Thru Hull 8 Vernae Tube 8" x 10" All Connections Are With Trident Single Hump Hoses Exhaust Runs From Transom To Aft Engine Room Bulkhead
- Exhaust Brackets
- Fiberglass I-Beams
- Install Deck
- Salon Deck Floating Floor For Quietness
- 4 Custom NWT Hatches Drop In Without Hardware
- Aft Deck Glassed With 2 24 x 24 Bomar Hatches Installed
- Engine Room Shelving
- Boot Top
- Bottom Paint
- Engine Room Insulation
- Visor
- Lift Kit On House
- Steering Bulkhead - Standard L shaped
New Engine; Owner can provide or we can supply at our cost
Kit boat package is intended for a new build order
Construction time approximately 16 weeks
Ready for Finishing: $148,000
